Question about Samsung (SH-S162L/BEBN) DVD RW Burner
Can i connect this dvd rom drive to the av ports on my tv.if yes how and which points do i use on the rom
  • 212 Answers
It havnt any output ports for direct watching.u can install a tv card on ur pc,then connect the output ports of tv card to the TV.if u know some electronics,u can find circuit schematics for making a board to playing only some audio formats by connecting the drive to it.
Posted on Aug 11, 2010
WHAT DO I PLUG IN THE BACK OF THE TV/DVD COMBO?
You may not have AV ports, AV ports being the ports that you would plug in a yellow video and a white audio cable into, so you may want to take a look at some adapters. Maybe an HDMI to AV adapter?
Tmvel mini RCACVS 3 RCA Composite Video AV to HDMI Converter for TV PC PS3... This one may cost you a bit, but if you don't have AV ports, but do have an HDMI port, this should work.
Dec 09, 2015 | Video Game Consoles & Games
Connecting a portable dvd player with only an av port to a tv
There is a special AV cord that connects to a TV ,
MINI PLUG TO 2 RCA , one is ( yellow) VIDEO & the other is AUDIO , get it at RADIO SHACK or WALMART , hope it helps , AJ
Nov 14, 2009 | Insignia PD10135 Portable DVD Player
Iwould like to update this twinhead laptop P90 to a windows 2000 or newer and i would also like to know if i can hook up a portable DVD rom to it as well.
You can put XP on it if you want and yes you can connect a external DVD ROM to the USB port.Its hard to say if the DVD ROM will play well or not though.If the TWINHEAD as a onboard cd drive be sure to set it as your first boot device then the HDD.If it does'nt have a onboard cd drive set it to boot from your USB first then the HDD.Good luck.
Aug 11, 2009 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Windows XP Professional does not crecognize dvd rom LG gdr 8162b. Is this rom compatible with XPP? Andre
YES IT IS COMPATIBLE WITH XP PPROFESSIONAL. CHECK THE CABLE THAT CONNECTED TO MOTHERBORD. AND ALSO THE PORT OF MOTHERBOARD.
Apr 12, 2009 | LG (GDR8164B) Internal DVD Drive
Disconnected system to install new carpet now i'm stuck
Try these...
1. Identify the Video out,Audio Out ports of the player. Normally they will be marked as AV Out for video,L(Left Audio) and R Out.
2.Identify the Video In,Audio In ports of the TV
3. Connect AV Out from the DVD to the AV in of TV,Audio Out of the DVD to the Audio in ports of the TV.
4.If the TV is Mono (means, with a single Audio in), connect to any one of the Audio port of DVD.
Mar 13, 2009 | Televison & Video
I have purchased a new DVD Player. Please help me connect to a TV with cable.
You need a Scart cable to connect the two. The instruction manual should tell you which port to connect to on the DVD (usually TV). The port on the TV should say AV in or similar . Sometimes you have to tune a TV channel to view the DVD but usually if you select AV on the TV it will play automatically.
Oct 08, 2008 | Televison & Video
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd-rom icon missing
Check: 1. if on pressing the eject button on the drive, the DVD loading arm comes out. 2. if yes, replug your IDE cable. 3. If it does not work try using another IDE cable. 4. If still the same problem, connect it to anothet IDE port. 5. If the problem is still there get your DVD drive checked. I assume you have not fiddled with the jumper settings.
Sep 30, 2007 | Computers & Internet
Samsung (SH-S162L/BEBN) DVD RW Burner Logo
85 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
