Not sure what I should put this topic. Anyways... I can't start my Dell Xps M2010. I left the computer for maximum 30 minutes. I didn't shut it down, just let it be. When I came back after eaticng the screen was black as it always is. I touched my mouse to get it on but nothing happend. After spamming the mouse and keyboard without success I shut it down on the startbutton. Now when I was going to turn it on again and it started, the start-button, bluetooth-button etc is blue as the should be. But it the screen is still black. Now I have restarted the computer millions of times. Two times when I first restarted I could see the Dell screen loading, but then It went black again. Now it's always black. You can't open the CD, or anything else. I thought my adapter was broken, but it isnt, It works as it should¨I think. I've tried it on other laptops, and it works. So I started search on this problem and found out that ít has happend for many. What I now understand it can be the video-card, hard-drive or something else inside the computer. I don't really know what I should do. I must get access to my computer soon again. Should I try to open the computer, or let it be? And I got no clue how to open the computer, get out the video-card or something else and clean it. Please help!
  • swufabuda
    swufabuda Aug 07, 2010
    It could be overheating. when you use your computer do you lay it flat, or do you prop it up somehow to let more airflow through the computer.
  • ekeus Aug 07, 2010
    Hey, yes I'm afraid I have always had it lay flat on my table.
    Champion:
  • 219 Answers
Does it work at all now? If so I would consider get something like a laptop cooling system, since this is not your normal laptop some research is in order to get something that will work the best. I think I would definately give Dell a call and see if they have any solutions. Hope this helps.
Posted on Aug 07, 2010
I have Dell XPS M2010. Windows Vista 32 bit. 350 bluetooth module The mouse connects and works well. The keybboard won't pair. I put it into discoverable mode and the three lights next to the power...
The solution is to formn a class action suit against DELL for this overpriced piece of junk. I went through 3 of them and they all failed.
DELL left these dogs out there in the market until the warrenties expired on all the M2010 machines and now they will charge you for their failure to build a solid product.
The Bluetooth Access Icon is nowhere to found in the control panel, so the manual is wrong as well.
DELL is acting irresponsble and needs to be punished. Let's form a Class Action Suit today.
Apr 14, 2011 | Dell XPS M2010 Wireless Bluetooth Keyboard
XPS M2010 boots in and everything works but fans
You can try installing this program that controls the fans on a Dell laptop. If this does not work you have a hardware issue with either the fans or the main board.http://www.diefer.de/i8kfan/index.html
May 29, 2010 | Dell Inspiron XPS M2010 Notebook
Hi, there are some vertical red line (Not a solid line but just a group of red dot) On My XPS m2010.It just come from computer starts till it comes to windows. Some says it was a motherboard problem, some...
The M2010 has a separate discrete video card from the motherboard.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=M2010+video+card&_sacat=See-All-Categories
If the dots are not seen in Windows, then it might just be a BIOS glitch (Try flashing to most current)
I'd only bother with it if the problem exists in Windows and the Diagnostics
Jan 22, 2010 | Dell My XPS M2010 Notebook
I have a xps m2010 laptop.. lights flashes but screen wont come on
Which light flashes?
You can try to run the diagnostics, while the computer is off Press and hold the power button with the Fn key,
If you have bad hardware it will an annoying sound.
This can help minimize the problem.
If it gives you the sound you can post here the LEDs on the keyboard so i can tell you what it means or simply you can contact dell tech support for further help.
Jan 18, 2010 | Dell My XPS M2010 Notebook
My dell xps m2010 charger not charging its battery but turns on my laptop when i plug the charger in.
most probably your battery is damaged! try another one in a shop and you will know for sure
Oct 27, 2009 | Dell My XPS M2010 Notebook
My Dell XPS M2010 came with Dell Premium Remote
Why not, you need all the resources you have to run other programs.
Sep 17, 2017 | Dell Televison & Video
I have lost sound on my Dell XPS M2010
Yep - this I run into every start up, or every awake session from Standby - the problem is that the default sound device changes - I've gone through the control panel, and put a shortcut to the Sound mechanism in my taskbar - then when it changes, I just modify back to the Speakers/Headphones setting - I usually have to change stations on Pandora, or skip to a new Youtube, but it all works our very quickly.
May 29, 2009 | Dell XPS M2010 Wireless Bluetooth Keyboard
Dell XPS M2010 Starting Problems
If they've changed everything else, why didn't they replace the power supply? That's the next part to target for replacement, other than the on/off switch (or button) itself. With no system board beep codes it's apparent that the mobo isn't gettting any juice at all.
Also try disconnecting everything from the mobo but the power supply - including pulling add-on cards. One or more attached devices may be contributing to the problem. If it comes to life start adding things back until it fails - you've just identified the culprit.
Good Luck!
May 22, 2009 | Dell Inspiron XPS M2010 Notebook
Ok. Here is the thing. I hope everybody sold their problem, but I will just post for others who may experience the same thing.
1st believe it or not : there is nothing wrong with motherboard, as when you press the power button, computer will shut down. with defective motherboard it will just continue running untill you will unplug it.
2nd believe it or not : it can not be battery issue or hard drive issue, because it does not make any scenes in any way. I have to agree that hard drive on the right is semi-correct answer.
REASON:
IT is video card that messing up everything. And it is located right under right hard drive. That's why when somebody removed hard drive he/she accidentally corrected the cooling system of video card , which returned M2010 to live.
CONFIRMATION:
1. First remove the top cover from the computer. There are 2 sides the plastic things. If you look at the back of your laptop you will see 2 small holes , one on every edge of the back. You stick something there it will loose the front cover.
2. unscrew all the screws hat have ">" or "<" signs next to them. there are something about 15-16 screws in total: this will allow you to open the cover under wich you can find the motherboard and stuff. When you open the cover pry to start the computer, and you will see that fans will not start even after 1-2 minutes after you hit the power button.
3. Remove the right hard drive and under it you will find screws A, B, C, D (silver) and also 1,2,3,4 (black) unscrew the black ones first, them remove video card with the cooling mechanism. now try to turn on the machine. you can see that after like 20-30 seconds fans start working which means that motherboard is fine and it was the video card that was giving problems.
SOLUTION:
1. I am not sure what causes the issue but I have fixed it this way:
uscrew silver screws and disconnect cooling part from the actual video card.
2. clean both, video card and cooling system not touching sky blue foam ICs. That staff is needed to cool the chips on the video card.
3. let them dry for an hour or so after cleening, than apply some Thermal compound, thermal paste and re assemble the video card with the cooling staff. (mek sure no screw is loose or something)
4. put it back and turn on the computer. If it works , whell .. it works now :)
if not then either you levae some liquid on the video card or screws are loose. try to play a bit with screws. but my personal suggestion is just to wait for a minute or two until video card gets hot and fixes liquid problems itself :)
Try it. It worked for me perfectly ...
Jul 23, 2008 | Dell My XPS M2010 Notebook
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
