MY 90 SERIES KENMORE WASHING MACHINE FABRIC SOFTENER DISPENSER DOES NOT EMPPTY
  • foster9544 May 04, 2008
    Thanks, I'll try that.
  • foster9544 May 11, 2008
    That was it! Thank you so very much.
    Marcia
    Genius:
  • 1,028 Answers
If agitator mounted pull off ..may be blue ring at base if so pull up and lift dispenser off or newer type twist off..soak in hot water and flush out if front mounted dispenser clean as good as possible
Posted on Apr 27, 2008
My Kenmore 400 series washer does not seem to be releasing the fabric softener properly. It ends up all around the top if the barrel and spotted on my clothes as well. Anything I can do other than g
the dispencer can at times become plugged with old soap and farbic softener and should be cleaned every so often. if it cannot dispinse it will shoot out the dispenser all over when it goes into spin. the lines can even get plugged up and not allow fabric softerner to flow , u may want to remove fabric hoses and clean them
Nov 08, 2014 | Kenmore Washing Machines
Kenmore 600 series fabric softener dispenser clogged
How do I make the waher Kenmore drop the fabric softener
Aug 25, 2012 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
I have a 90 series washer, about 15 years old, the fabric softener dispenser is not emptying. I have pulled it off and cleaned it, but it only works once after I do that.
HI,
I would re-clean the dispenser, use hot water can completely clean this. If you don't add water to fabric softener, it will cake up and cause this issue. This problem can also cause spotting and appear to have issues on clothing. Just soak dispenser using hot water and pressure to clean out all the ports and openings within the dispenser.
I hope this helps, worst case you can replace dispenser, but I would just clean it (cheaper).
Aug 11, 2011 | Washing Machines
My fabric softener dispenser does not release softener
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Oct 09, 2010 | Kenmore Washing Machines
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Fabric softener dispenser
Have u made sure that the dispenser is click in properly
Oct 26, 2009 | Washing Machines
Where do i put the softener
some model units do not come with a softner dispenser, ask sales rep at sears it might have been an upgrade model in the 90 series that had that dispenser??
May 16, 2009 | Kenmore 23012 Top Load Washer
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Oct 10, 2008 | Washing Machines
MY 90 WERIES KENMORE WASHING MACHINE FABRIC SOFTENER DISPENSER DOES NOT EMPPTY
I am having the same issue. I do know that the reason you don't see any physical provision for it to drain is because it is drained using a siphoning effect. water is put on top of the fabric softener until it reaching a point where the siphoning begins. Once the siphoning begins, the whole thing will drain out until there isn't much left (however there will always be a little water left). I know siphoning works with my drawer b/c when I take it out and fill it with water slowly until the siphoning begins, the whole thing drains out. There must be another reason why the fabric softener isn't working.
Apr 27, 2008 | Washing Machines
Washing Machines Logo
398 people viewed this question
Top Washing Machines Experts
