Question about ASUS P5S800-VM Motherboard
Board starts to boot into windows then restarts and shutsdown
    Habit-Forming:
  • 96 Answers
Did you change the memory? I put some memory in mine and it made it do that
Posted on Aug 07, 2010
Push power button, it runs,shutsdown &restarts over & over
if the BIOS configuration didn't work, try to remove 1 memory at a time then boot up.(if you have 1 memory on each slot)
thanks
Mar 30, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Can not log on to windows XP after installing the driver display shutsdown while entering to windows.
If its a Desktop computer, Switch it off, disconnect the power cable, open it up and remove the Graphics card from its slot. If you have a network cable, remove it too and try to boot the computer.
If that fails, then try to boot your computer while pressing F8 which will lead you into safe mode. Try and see if the computer can boot in safe mode. When you boot in safe mode, go to start, then open Control panel and go to "Add and Remove Programs" tab. Uninstall the driver that you recently installed. If you can not see them in Control panel, then click on start, right-click on "My computer" and go to its properties. Then go to device manager, and look for any yellow question mark or exclamation mark. This will normally be visible on the device that failed installation. Then right click on it and select uninstall, this will remove your corrupt drivers. Restart the computer and try to boot is normally
Sep 06, 2011 | Abit RADEON R9550-Guru Graphics Card ATi...
Pc shutdown after 15 minutes i think problem in processor
>if system shutsdown and does not restart, yes it will be a problem on
processor but you can try updating bios as well
> if system shutsdown but still restarts it might be getting bluescreen but you just not able to see it
Jun 05, 2010 | Intel Computers & Internet
Pc shutsdown after 1min or so
follow this steps bro. 1. restart your pc. 2. press delete button till 1long beep correspond while on reboot mode. 3.configure your BIOS and set first boot for cd or dvd rom drive. 4.insert your windows xp installer that u've use, then just select repair mode operation to fix your operating system files.
May 15, 2010 | Computers & Internet
Windows Home XP system shutsdown abruptly.. just before that there was a message " device lost" what is the reason for the it and how resolve the issue?
I would first try to boot into safe mode, by pressing the F8 key while booting. A menu will come up, select "safe mode" after booting into windows from the control panel use the device manager to see if there is an exclamation mark next to a device. If so you can temporarily "disable" this device then try booting normally into XP.
Feb 21, 2010 | Microsoft Windows XP Professional Edition...
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
My HP Pavilion 753n starts to be and then
It is the power supply
In hp the power supply they use does not die on you completely; it will start but not feed the computer.
So change it to generic brand and every thing will work fine.
Jan 02, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
PC TROUBLESHOOTING
Your computer may be Virus'd
Try tapping the F10 key as the PC is booting up,,and choose safe start.
If you can get that far, you can use system restore to restore to some previous date.
Then Scan for Virus and Malwear.
Jan 28, 2009 | Microsoft Windows XP Home Edition
My computer is restarting over and over....It's stating that a program has unexpectedly shutdown and that windows needs to restart. It's a HP laptop
If it gets into windows and then shutsdown after a very short time. Then start it again and click on the start menu A.S.A.P. click on the run command and enter:
shutdown -a
Then O.K.
If it no longer shuts down after typeing in that command then you have a virus and need toi run anti-virus software to clean it out. If this is the case then you also have the virus in some of your restore points and they need to be cleaned out as well.
Good luck. Be more specific about at what point it starts to restart.
Jun 06, 2008 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
Non Booting Machine
try to boot in safe mode,if the problem persists then you try to repair your windows
Apr 22, 2008 | IBM ThinkCentre S50 8183 - P4 3 GHz...
ASUS P5S800-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
