Question about Zanussi ZHF470 Electric Double Oven
The bottom oven dosen't heat up yet the fan and the light still works. The model is Zanussi ZU270F.
  • Zanussi Master
  • 3,463 Answers
You need to replace the oven element, located behind a removeable panel at the rear of the oven compartment.
Posted on Aug 07, 2010
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
Oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
May 14, 2010 | Zanussi ZDQ495 Electric Double Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Zanussi Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens
if the oven fan and light are not working, then the clock probably needs setting. if oven fan and light work, but no heat, then the problem is probably the circular element round the fan. remove the back panel of the oven and you can often (but not always) see the damage. replacement of the element is straightforward
May 06, 2007 | Zanussi ZBF660 Electric Single Oven
Zanussi ZHF470 Electric Double Oven Logo
161 people viewed this question
Top Zanussi Ovens Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
