Question about Logitech 250 Headset
Can here but cant talk on my mic
The audio in put is very good i can here every thing but when i get ready to talk no one can here me
  • fishryt Jun 02, 2008
    when i use my headset in yahoo messenger it doesn't work but it does in paltalk what is the problem?
  • Logitech Master
  • 13,433 Answers
Check your sound settings the mic is probably on mute. or then the program your useing is useing the wrong input for the microphone.
Posted on Apr 28, 2008
Have a general lee transmittes.canhear myself talking but cant hear any response,changed mic,antan,coaix,still no change,need help
See if you can connect an external speaker and see if you get received audio. You might also see if you can connect directly to the audio output on the main board directly to see if there is detected audio.
Sep 29, 2014 | Radio Communications
Why cant i talk or hear any body on my mic?
Since it is Bluetooth, you have to pair the Bluetooth to your host computer or device. Find the correct window or screen and put it into discover mode, do the same with the headset. RTFM
Aug 11, 2014 | Jabra BT2070 Bluetooth Headset
NOT RECEVING OR TRANSMITING
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
Jan 04, 2013 | Radio Communications
I set up my web cam and i hear my sister when she talks but she cant hear me
well the first thing that you got to check is that if the web-cam has an inbuilt mic to it
If there is no mic then you will have to attach a seperate mic/headset for voice
Also check if its USB port or normal Audio/Video output...if it had audio/video cable then you will have to attach both the cable to the correct port in the Cabinet
If it has USB output cable with inbuilt mic then try to unistall and reinstall the driver software and attach the the webcam only after installing the drivers
Jun 14, 2010 | Logitech Webcam
Why i cant talk in headphone i can hear the voice in computer. i installed nymgo talking internationally i can herta the voice but i cant speak the speaker placed in my mouth does not have voice
Click on start->control panel->sounds and audio devices->audio tab->under sound recording click on volume tab and uncheck mute all and anyother mute.
Oct 03, 2009 | Audio Players & Recorders
I don't have voice, have carrier. Cobra 29 ltd
there are several things that might be responsible for the absence of modulation when speaking into the microphone. a defective mic cartridge, a broken audio or audio shield/ground wire in the mic cable or mic plug or a defective push-to-talk switch in the mic itself, for starters. if all is well here then the amc and transmitter speech stages in the transceiver will have to be considered next. locate and check with a known good mic wired for the radio in question. let me know.
Jun 06, 2009 | Cobra 29 LTD CB Radio
No rx
so the swr is fine antenna has not been hit by lightning i assume as the swr would be all wacke out check to see if the rf gain is turned all the way down maybe if you have little ones they play with everything as i know all so well. or mabe the squelch was turned allt the way up if either turn squelch down all the way and turn the rf gain all the way up if not the audio chip on the rt side of the board could be shoted out if the radio has pa put switch to pa with external speaker attached key mic and talk if you here yourself talking the chip is good. by the way has the radio been tweaked any time recently it may be also alignment problem??
Mar 09, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Cant talk through mic
Sounds like a bad or miswired mic. Try a new mic ( use the proper cobra mic ). If the problem still continues, check all the swiches on the front of the radio and make sure you don't have any cold solder joints ( broken lead to board connections ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
I cant talk
-> make sure mic is connected correctly in the correct slot to the CPU
->go to control panel-> sound and audio and there is seperate tab for "microphone"-> have th volume to be full
-> you can test whether the mic works there itself.
Nov 10, 2007 | Labtec C-322 Headset
Logitech 250 Headset Logo
106 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
