Question about GE Microwave Ovens
Need a paper cabinet template for the ge spacemaker XL1800 micor
MicrowaveSvc
  • 9098 Answers
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
vitg55
  • 78 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 15, 2008
  • 338 Answers
SOURCE: ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Posted on Jan 19, 2009
SOURCE: need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Posted on Apr 09, 2009
fieldy14
  • 456 Answers
SOURCE: GE Spacemaker XL1800 suddenly won't heat
the 99 percent reason for this is the magnatron assy.
Posted on Jul 12, 2009
I'm installing a GE spacemaker JVM130K but don't have the mounting templates where can I find them?
I checked the manual and it did not provide one or mounting dimensions. If you already have the unit, reverse engineer a template... You can either do it by holding paper to the sides and marking the mounting points, or simply take the measurements for the mounting points from a good known reference - such as the front if you are looking to moun the front flush to the face of the cabinets.
Dec 04, 2014 | Microwave Ovens
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
Need installation instructions for otr microwave please
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
260 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
