Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
Communication error download - Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Nov 25, 2012
Paperport 12 "Cannot communicate with
Nuance's fix for Paperport 12's "Server busy" error (downloading and copying an updated file) also fixes this "cannot communicate withthe all-in-one indexer error". See Nuance's fix at:http://nuance.custhelp.com/app/answers/detail/a_id/5949/~/%22server-busy%22-error-when-using-the-all-in-one-search
Steve Baxter
Forbes Baxter Associates
www.forbesbaxter.co.uk
Jun 04, 2011 | Nuance PaperPort 12
Command error on epson 9600
Are you sure it is a 'command error' and not a 'communication error'. I could not find anything on a 'command error' but did find this on a 'communication error'.
Q: Why am I getting a communication error when I try to print?
A: Check the following if you are getting a communication error when printing:
Make sure the type of driver you installed matches the ink type in the printer. Verify the ink type by checking the part number on the ink cartridges.
Make sure the printer interface setting matches the connection type you're using. By default, the printer interface should be set to Auto, which supports all connection types.
Check the physical cable connection and make sure the cable is not be longer than 10 ft. You may want to replace the cable.
You may also get communication errors if the printer name is not set correctly. Contact EPSON at (888) 377-6611 or (562) 276-1305 to get instructions on how to verify this.
You might want to check to see if you have the current drivers for your printer and operating system; a new driver can be downloaded here.
Trust this is helpful.
Dec 14, 2010 | Epson Stylus Pro 9600 InkJet Printer
"Communication Error" message
Use a card reader to download your pictures to a folder you create on your desktop.
Sep 29, 2009 | Fuji FinePix A360 Digital Camera
An error code 1706 keeps coming up. It says "no valid source could be found for product Dell Connections (Support Software). "The Windows Installer cannot continue. I'm not trying to install anything and...
Microsoft says that Error 1706 is a Microsoft Office Error code which
indicates that required files can not be found by Setup. Since you
are trying to install new programs I feel that this is probably the
correct interpretation of your error code.
Microsoft's Knowledge Base Article 297834,
http://support.microsoft.com/default.aspx?scid=kb;EN-US;297834
Jun 26, 2009 | Dell Computers & Internet
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
Printer does not Communicate (connect) following Microsoft SP3
I figured out the solution. Download the printer driver here http://downloads.lexmark.com/static/229-1-0-486.html#
Jan 28, 2009 | Lexmark Z600 InkJet Printer
We get a communications error when receiving a fax from the HP 1050 fax
You need to update the firmware
You can get from the link below
HP firmware
On the software download page, select your Windows version.
Locate and select the firmware update.
Follow the directions to download and install the update
Oct 28, 2008 | Office Equipment & Supplies
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
