Question about Hobart Airforce 250ci Plasma Cutter 12 Amps
Hi I have a hobart airforce 250ci 2 and a half year old lightly used plasma and the power doesn't come on
    Problem Solver:
  • 8 Answers
Check your ground and make sure the ground is clean, if not sand it slightly where it's shinny then try tighten the ground clamp and tighten the ground clamp on the machine itself. Be sure the breaker is not tripped for the machine in the main electrical panel as well check that the electrical cord has not worn down from use, you may have to replace the electrical connector if it is badly worn. you can buy at any hardware store, you will want to buy a 15 amp male connector. If this does not sole your problem please let me now for more help. also be sure air is working for the machine.
Posted on Aug 07, 2010
Why dont i have any power to my hobart plazma cutter
Maybe blew a fuse . maybe malfuncttion. i would contact company for proper assistance.
Customer Service Hobart Welders
Mar 03, 2016 | Hobart Airforce 250ci Light Weight Plasma...
Will not arc
Sounds like the voltage is not going to the tip. I would suggest taking this in for repair.
Dec 07, 2013 | Hobart Airforce 250ci Plasma Cutter 12...
Machine turns on, air compressor runs but will not strike an arc
sounds like the voltage is not getting to the tip. I would suggest taking this in for repair.
Was cutting with it and it just kicked off like a breaker tripped, no power at all.
check the cable going into it,then the nozle i think the unit has a breaker type switch ? push it all the way down then back up again
Jan 07, 2010 | Hobart Airforce 250ci Light Weight Plasma...
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Need manual for hobart g-250 welder
Go to this page on the Hobart website....you can enter your model and the serial and it will allow you to download the manual...
Click here
May 25, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Hobart 250 has power to unit, but will not run.none of the lights come on.
Sounds like you have more than one problem. Check all fuses. Bringing it to a welder repair shop might be a good idea. Welding suppy houses may be able to help you in your area, and maybe recommend someone.
May 01, 2009 | Hobart Airforce 250ci Light Weight Plasma...
Hobart Airforce 250ci Plasma Cutter 12 Amps Logo
378 people viewed this question
Top Hobart Welding Tools Experts
Robert Lee
Level 1 Expert
Delage guy
Delage guy
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
