Question about Cycling
They are very hard hardy any movement at all - Cycling
  • dereklivings Aug 07, 2010
    327 zoom front forks are hard there is little to no movement at all
    no i am not having trouble with the pedals Its the zoom front forks that are problam there is little to no movement at all making it a bumpy
    ride is there any way i can service them myself
    thanks derek
  • 10,515 Answers
Kindly mention the problem in detail along with the make and model of the bicycle.
Thanks!!
Posted on Aug 07, 2010
    make is Salcano Baki
  • taran_2005
    taran_2005 Aug 07, 2010
    Thanks for your response!!
    A generic procedure to fix the problem is explained below :-
    If a bicycle pulls to one side when you ride it hands off, the fork is bent. To prevent this, once a year, or whenever the fork binds or clicks as you steer, inspect and grease the bearings. If any bearings are worn, pitted, or discolored, replace them all.
    Each set of bearings rides between a cup and a cone. The balls may be loose or held in a frame called a cage. Tightening the upper cone will eliminate play in both sets of bearings. If the top cone is set too tight, the fork will bind and be hard to turn. Tightening the locknut may cause the cone to rotate too, requiring its readjustment.
    Remove handlebar and temporarily hang bar on frame. Unscrew locknut, which may be either a hexagonal nut or a slotted C-nut. Take the fork and clamp it the edge of a flat surface, and using a board and hammer, hit it a few times gently to get it back into shape like the other side of the fork. Stand the fork upright and check to see if the fork is now straight. If not, hit the frame with gentle pressure with a hammer a few more times until straightened. The trick is not to remove the paint from the bicycle.
    If some paint does chip off, sand, prime and re-paint the areas.
    Lift off locknut and headlamp bracket if any. You may then disconnect the cables to free handlebar completely or let bar remain hanging from frame. Unscrew top bearing cone and remove upper bearings. Replace pitted or flattened bearings with a new set of the same size. Clean old grease from parts with kerosene.
    Holding frame tightly to fork, lay bike on its side atop newspapers. Separate fork and frame, catching loose bearings in folds of paper. Clean cup and cone. If bearings are not worn or damaged, clean each set of them separately in kerosene. Dry them between the palms of your hands or in clean, lint-free toweling.
    Fill the lower bearing cup with multipurpose grease, sold in bicycle shops. Press the correct number of bearings well into the grease so that they will not fall out.
    Spread grease on bearing cone and lower the cycle frame over the fork column, being careful not to dislodge any of the bearings. Inspect and clean any balls that drop.
    Partially fill top cup with bicycle grease and install upper bearings, taking care to install the right size and number of balls and not to drop or damage any of them.
    Grease top cone and screw it on finger tight. Replace bracket and locknut. Adjust cone to eliminate all play. Tighten locknut, check for binding. Readjust if necessary. Now replace the handlebars the same way you removed them and tighten and adjust to height desired. Dropping your bicycle on the ground will cause the fork to become damaged. Stress the importance to your children, that using a kickstand, prevents this from happening. Also, keep from hitting curbs or other objects while bicycling with the sides of your fork.
    Good Luck!!
    Thanks!!
  • 11,896 Answers
If the pedals are extremely hard to turn, then bearings are likely dry and need to be removed and lubricated.
  • 1 more comment
    its not the pedals i am haveing trouble with its the front forks they are very hard there is little to no movement making it a bumby ride
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    Some of these are adjustable and can turn according to weight. Some have a little nut on them you can turn to relieve pressure. Others are not adjustable and just need to be replace or well lubricated
  • Nate Stansfield
    If you have an older style 'quill' stem, then you can
    probably adjust the height a little bit. These are old-school, but are
    still often found on cheaper bikes. If the front of the stem doesn't
    have a removeable faceplate that clamps the handlebars, then you
    probably have a quill stem. They go into the fork steerer tube and clamp
    in place with an internal wedge. To adjust them, you loosen the bolt at
    the bend in the stem and raise or lower it to where you want it. Pay
    attention, because there is a 'minimum insertion' mark near the bottom
    of the stem.....make sure that mark isn't exposed. You can set the stem
    height anywhere above that mark.
    If you have a more modern stem,
    it will clamp around the fork tube rather than inside of it. These
    stems usually have 2 bolts to the rear edge that tighten around the
    tube, and on the front they'll have 2 or 4 bolts that clamp the
    handlebar. With this style, you're limited by the length of the fork
    tube. You may see some spacers below the stem or above it....if you have
    those, then you can adjust your stem a little. If not, then the only
    way to change your handlebar height is to buy a fork with a longer (or
    uncut) steerer tube, or to use a different handlebar with a different
    height/bend to it.
  • 17,970 Answers
We dont understand excalty what is the problem or what part is wrong there, but sure that this link can help as reference guide: fixed.html
If you need specific details, tell us news.
The contents in the screen of my psp is shivering
1. Turn your psp off.
2. Then turn it back on while pressing the R button to put it into recovery
mode.
3. Then go down to CPU setting and change CPU Xmb speed to default
and also have Game CPU speed at default.
4. Exit and boot up psp and everthing should work.
May 19, 2012 | Sony PlayStation Portable (PSP) Console
Notebook demonteren
==== http://www.proxy4biz.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to====http://www.proxy4biz.com ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
Oct 04, 2011 | Acer eMachines 520-2890 Notebook
Workshop manual
==== http://www.voguecatch.com ==== top Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag
Jul 10, 2011 | 2006 Honda CBF 1000
How to disable anti theft mode in acer 18.5 lcd monitor manually?
If you have activated the anti-theft mode on your Acer monitor then disable it in the following method.Turn off the monitor, while holding the 'menu' button, turn the monitor back on .Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 12, 2011 | Acer AL1916W 19" LCD Monitor
My pc is really slow. Do i need new ram?
that would be a good way to speed up your computer just make sure to use and anti static writband to avoid shorting out the computer
May 07, 2011 | Computers & Internet
Gt s 5233 samsung mobile reset code please
Hello thanks for using Fixya
Type #*7337# or try this to hard reset
*2767*2878# or *2767*3855#
It will ask you to confirm, Press ok & if ask phone code then Default phone lock code for samsung if it didn't changed before then it is 00000000 (eight zero's)
Note:
Remember one things hard reset will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below and then give testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 27, 2011 | Samsung Star GT-S5233 Cell Phone
I think my battery is dead in my Casio Oceanus Wave Cepter watch. It has been stored in a drawer for a couple months and it is not working now. Does it need to put in the sunlight or do I need to replace...
==== <a href="http://www.voguecatch.com" target="_blank">http://www.voguecatch.com</a> ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== <a href="http://www.voguecatch.com" target="_blank">http://www.voguecatch.com</a> ====
New era cap $16
Oct 26, 2010 | Watches
Band broke and need a replacement model 5000ss
New era cap $16
Oct 26, 2010 | Jules Jurgensen 5000SS ( ) : Swiss Quartz...
Touch screen is not working for several functions on tissot t-touch: notably started with altimeter, then meteo, now alarm.
==== http://www.voguecatch.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== http://www.voguecatch.com ====
New era cap $16
Oct 23, 2010 | Tissot T-Touch T33159851 Wrist Watch
Cycling Logo
23 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
