Question about Smartpool Nitro Robotic Cleaner and Caddy
My Nitro doesn't start. I have unplugged it; it has been without power for a week but will not fire back up. Is there a reset?
    President:
  • Smartpool Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
There is no reset in these cleaners. Test the power supply for output voltage. If it has power out you'll need to send it in for repair as the rest of the possibilities require opening the sealed motor units. If it doesn't, replace the power supply. For a quote on parts or to send it in for an estimate, please contact us thru www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 17, 2010
My GE SMR03BASWW is not turning on. Came back from being gone a week and it seems to just stop working.
i don't know. you could try to unplug it and test the wall receptacle with a night light or similar to see if power is on.
if no power there, you could run a temporary extension cord to a receptacle that has power. you must find out what else is on that line that caused an 'overload'. if your small fridge works using the extension cord and that is all that was using that line, you should considering calling an
electrician. you may have a burnt out fuse or a tripped
circuit beaker at your home's main electrical panel. there
is a danger of shock or fire if you to just change fuses or reset circuit breakers without knowing the cause of failure.
Apr 03, 2018 | GE Refrigerators
Dodge Nitro ECM diagnosis
Are you getting spark on any cylinders ?
Apr 13, 2017 | Dodge Nitro Cars & Trucks
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
How to reset oil light on dodge nitro
This one is simple...
Insert key in ignition and turn to on position (do not start engine)
Press the accelerator Pedal fully to the floor and release 3 times back to back.
Immdeiatly cut key off and remove from switch.
This should do it without a problem,,
Hope this helps
ROger
Feb 08, 2012 | 2010 Dodge Nitro
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
Jan 20, 2012 | Whirlpool Washing Machines
Washer won't start, control lock lite on?
Try unplugging the washer for 30 minutes. When you plug it back in, the power board should reset and allow you to start a new wash cycle.
Oct 25, 2011 | Whirlpool GHW9300 Duet Washer
Childlock flashing unable start machine
Hi there, without some details of the make and model of your machine I can't tell you what buttons to press to perform a reset of the machine, however, this is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up. Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Aug 08, 2011 | Washing Machines
Reset the router
1. On the back of your router there is a little black reset button. Use a pen or paper clip and press down for 10 seconds. Make sure the lights on the router stop blinking for one second. Release the button and make sure to reset your wireless security and network ID.
2. If that doesn't work just unplug your routers power cord. This is the easiest way to reset your internet connection without resetting your router to factory settings.
3. If neither of those work, unplug the power cord of your modem. This will completely reset the internet connection without resetting the routers settings.
Jul 09, 2011 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Nitro car wont start?
Motor could be damaged from getting too hot. I would try to reset carb settings back to neutral from the factory. The manual that came with the car should tell you how many turns out they should be. Also check the fuel lines to make sure they did not get damaged. Nitro motors normally run best at 210 - 240 degrees. Much more than 240 degrees can damage the motor. It is always better to run a little rich than lean.
Dec 30, 2009 | Cars & Co Remote Control Buggy Nitro Gas...
How do I reset my amp?
You unplug the power and plug back in by turning the key off for a few second then back on. There is no hard reset on amps as the power is switched on/off by the remote wire. If that doesn't work your have an issue with your amp or wiring..
Nov 01, 2009 | Nitro BMW-485 Car Amp
Smartpool Nitro Robotic Cleaner and Caddy Logo
690 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
