Question about Craftsman 118 pc Dual Marked Mechanics Tool Set
Primer bulb won't hold prime on Craftsman chainsaw. Runs few seconds then dies.
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Remove the carburetor and check the impulse passage that runs from the crankcase, through the gaskets and heat insulator, to the carburetor base--these impulses cause the carburetor to pump fresh fuel into itself. You may need to clean the carburetor inside and out with spray carburetor cleaner. Check the diaphragm in the lower chamber for softness and no damage. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors for theory and troubleshooting--this applies to other brand carburetors as well. Hope some of this helps!
Posted on Aug 07, 2010
  • analwon Apr 30, 2011
    What has this address to do with Walbro brand carburteors? http://www.drystacked.com Nothing as far as I could, or couldn't find. What did I miss?
  • drallim Apr 30, 2011
    That address used to take you to the Walbro site, but now requires additional address text: httpt://.drystacked.com/Walbro carburetor theory 27JUN2010.pdf If you do a web search for
    Walbro carburetor theory, this is the first entry. The site has been improved from it's initial iteration. Good luck.
Will not stay running
Not adjusted properly.
Dec 29, 2013 | Homelite Garden
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
Craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Sep 27, 2012 | Craftsman sears 18" Chain Saw Chain (...
I have a craftsman eager-1 4.5 hp mowerthat won't stay running. If I hold the primer bulb in, it runs. I've adjusted the screw all the in and it still won't keep running. Any ideas?
Do you hold the primer in or pump it? Pumping the primer forces the fuel into the intake bypassing the diaphragm's intended function. Assuming you pump the primer to keep it running your carburetor is dirty and should be cleaned. Ensure that your fuel is fresh and that your fuel can and fuel tank has no water in it. Ethanol in fuel will evaporate and cause condensation thus creating unwanted water.
Apr 20, 2012 | Craftsman Garden
PowerMac by McCulloch PM425AV-18 38cc. I have replaced the line from the fuel mixture tank to the primer bulb & replaced the primer bulb. Now the chainsaw won't keep or looses the prime. Now...
Are you sure you have conected the pipes the correct way round, the fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, nearest to the alloy pump cover, the other conection off the carb goes to the shorter conection on the back of the primer, the longer pipe on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Walbro WT891 carb on a Craftsman chainsaw. Carb is brand new, all fuel lines and fule filter replaced. I prime the carb with the little plunger, chainsaw starts up and runs out of fuel within 30 seconds....
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
Jan 31, 2011 | Poulan Garden
Starts but only runs for a few seconds
It seems to be starting on the prime (from the primer bulb), but the carburetor is not pumping fuel. If this is an older saw, you probably need to clean and re-kit the carburetor. Make sure all body screws are tight.
Aug 27, 2009 | Garden
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Craftsman 118 pc Dual Marked Mechanics Tool Set Logo
607 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
