Question about RCA TH1611 MP3 Player
It turns on for three seconds and says pearl then it shuts off
    Problem Solver:
  • 13 Answers
Is lock in or hold that would do it
Posted on Aug 19, 2010
Rca pearl th1602-a I turn it on all I get is the pearl emblem and it wont turn off. I have to pull the battery to stop.
My solution to a Pearl TH1602-A stuck on the pearl screen:
Download the firmware upgrade from RCA's website, run it.
RCA PEARL FIRMWARE DOWNLOAD window should open.
Remove battery from Pearl, keep out.
Press PLAY and hold while plugging into USB port,
when "initializing" progress bar moves, let go off play button.
On my windows, it installed some software and asked me to reboot. After the reboot I re-ran the Pearl firmware file and about 30 seconds later the start button was now available.
Click it. However, You will loose your music on the internal storage.
Oct 07, 2009 | Audio Players & Recorders
It says exceeded usable memory and shuts down and wont come back on
I haven't seen the exceeded usable memory message on mine, but I am familiar with Pearls not coming back on.
First, perform a reset buy removing the battery for at least 10s. Sometimes mine just shows the plain pearl logo (not the moving one) and then shuts off. Removing the battery for a while and then putting it back in always fixes it so that it shows the plain pearl logo for few seconds then displays the animated logo and starts normally.
If this fix doesn't work for you, then the firmware inside the Pearl is most likely corrupted, and can be easily fixed by running this software from the RCA website and following these steps:
  1. start the program,
  2. remove the battery from the TH1102 & wait at least 10 secs,
  3. hold the play button while plugging into usb,
  4. release the play button the the term "initalizing" replaces "searching",
  5. click the start button to replace the firmware.
Hope that helps.
Oct 06, 2009 | RCA Pearl TH1102 MP3 Player
Wont turn on
www.crackberry.com will help, just search in the forums for "recover a dead blackberry"
Jul 30, 2009 | RIM BlackBerry Pearl 8100
Radio keeps shutting off
When there is no signal around ur blackberry will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on,if this is not the problem then there might be some problem with ur phone.
Jul 12, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Radio connection shuts off every 30 seconds
Try taking battery out and putting it back in - have had a couple of problems with my own blackberry and this is advice I was given, and it worked! Might be worth a try anyway.
Jun 12, 2009 | RIM BlackBerry Pearl Smartphone
Antenna automatic shut off problems for blackberry pearl
I had this problem a few times, but only when I let the battery drop so low that the connection turned itself off to save what little life the battery had. Once that happens I just had to wait for the battery to charge back up so the connection could reestablish itself. If this is the case, just plug it in and give it time.
May 26, 2009 | RIM BlackBerry Pearl Smartphone
Blackberry Pearl keeps turning mobile connection off.
There might be some issue with the BlackBerry Device Software associated with the BlackBerry smartphone so Upgrade the BlackBerry smartphone with a newer version of BlackBerry Device Software and make sure that you have taken a backup before upgrading.
Feb 27, 2009 | RIM BlackBerry Pearl Smartphone
RCA TH1602 MP3 Player in locked
You should be able to force the Pearl into recovery mode by removing the battery, then hold down the "Play" button while inserting into USB port, after a few seconds, Windows should detect "USB Human Interface Device" (see Device Manager). Now you should be able run the firmware update. Worked for mine after it froze up one day and would not be detected as a USB device by Windows.
Nov 14, 2008 | RCA TH1602 MP3 Player
Pearl not working
blackberry when turned on shows hourglass and then turns displays security test then shuts down and then does it again
Nov 09, 2008 | RIM BlackBerry Pearl 8100
RCA TH1611  MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
