Question about HP Cameras
Can not get camera hp pb360t to allow me to review pictures. It freezes when I touch arrows- any of them. Battery is fully charged
  • HP Master
  • 4,924 Answers
First save any pictures that you may have into the card ....you can actually use a card reader and directly download them ..or use the cable for that ..
After that reset the camera to the factory settings from the main menu ...and also go to storage ..choose card ..and format the card directly into the camera ..this will erase all pictures..and this is the reason for what I suggested to save the pictures..
If the camera has no physical damage this should take it back to all functions ..
Posted on Aug 16, 2010
  • 11,896 Answers
Most likely your camera will need a fimware update. The update can be downloaded form hp's website.
Posted on Aug 07, 2010
  • sylviawilhid Aug 07, 2010
    What kind of update is this? fimware?
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    yes it is.
What is the maximum size SD card for HP pb360t
This information should be in the manual
Nov 28, 2017 | HP Cameras
Will let me review pictures, but when I switch to take pictures it shuts off
Try to check if the memory is already full, delete some files before taking pictures again. or Try to check the battery if fully charged also, review the manual, you might have to review the settings of your camera
May 12, 2011 | Kodak EasyShare Z740 Digital Camera
DOES THE HP DIGITAL CAMERA PB360T COME WITH A MEMORY CARD
You NEED to buy a memory card... I could only take 2 YES 2 pictures!!!!!!
Jan 06, 2010 | Cameras
Need user manual for HP PB360t, digital camera.
The manual can be downloaded here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=4104132&#
Dec 30, 2009 | HP Cameras
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
Camera turns off after reviewing two pictures
I suspect this a battery problem which has been described by many Sony users. The camera reads the battery charge wrong
and shut downs down.
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
Dec 10, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Cameras Logo
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
