Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Suction indicator is not spinning cant figure out what is clogged
  • Bissell Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on Aug 07, 2010
My dryson dc40 beater bar will not spin and there is no suction
The brush bar motor or one of the switches may be defective. If the brush is not spinning it will not pick up anything from carpet leading many to think it has no suction. Feel for suction down by the brush bar. If you have no suction it may have a clog or need new filters. Make sure the changeover valve that switches suction from floor to tools is working properly.
Mar 25, 2018 | Dyson Vacuums
Should hot air come out of hepa filter on shark navigator. Brush spins have suction cannot find clog
Yes the air coming out should be warm to hot depending on how long the unit has been running..Clogs are usually in the hose / pipe
Something caught sideways or a piece of paper
Sep 10, 2017 | Shark Vacuums
ProForce 1500 has suction but the brush roll motor stops working.
Clogged end caps could be restricting rotation. A common problem, especially where pet cleanup is concerned.
Feb 20, 2018 | Proteam ProForce 1500 Bagged Upright...
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
Jun 20, 2010 | Lindhaus 380 Diamante Bagged Upright...
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
Dec 11, 2009 | Euro-Pro NV31 Infinity Vacuum
No suction
Replace your belt. Remove the baseplate, remove the brushroll, place a new belt around the motor pulley, then around the pulley on the brushroll, and pull the brushroll back into place in the nozzle. Spin it by hand to make sure it spins, (otherwise you'll break the belt again,) and then replace the baseplate. Party.
-R
Feb 25, 2009 | Riccar 8850 Vacuum
Air flow indicator stays activated after filter has been cleaned. Brush spins, but very little suction. Dirt doesn't spin in cup.
Your vacuum is clogged. Check all of the air pathways, hoses, etc. The most common places to check are anywhere there's a joint in the airways, and also directly behind the brushroll.
-R
Aug 12, 2008 | Hoover U5507900 Elite Rewind Bagless...
Loosing suction
Well you did not state what model and brand this is, but usually if the hose or the dirt inlet by the brush roll gets clogged, then you lose suction. If you can't figure it out, usually there is a year warranty, take it in for warranty service.
May 07, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
115 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
