Question about Whirlpool Refrigerators
My refgr.'s compressor is defective according to service engineer.it's within warrenty period. should i pay the charges of gas filling.
  • Whirlpool Master
  • 43,501 Answers
Yes, most any manufacturere will pay for the materials, but NOT the labor...yeah I know it stinks!!! You buy new and figure you have a warranty and then they wack you with labor charges anyway... go figure...
heatman101
Posted on Aug 07, 2010
Cant find refrigerent leak on 04 trailblazer
Mechanics use dye or a device that "sniffs" for leaks since the gas is hard to see.
Putting in fluorescent dye allows you to see the dye with a black light.
The sniffer picks up a component of the gas.
If the system was charged before you replaced the compressor, the leak should be at one of the gaskets you replaced, or you have a defective compressor which is leaking at the pulley seal.
Jul 01, 2012 | Chevrolet TrailBlazer Cars & Trucks
Micromax x360 is howing head set symbol even without connecting the headset. i cant hear without headset.
Goto your nearest micromax servecing center with your mobile bill aand show the problem. If your mobile is warrant period then no service charge are require otherwise pay according to the service rate of the center.
May 03, 2011 | Home
Motor will run but frige will not get cold. I see there is a cripped off pipe from the bottom of the compressor. if I fit a service port at that point can I check for charge? and if none than put a...
When the gas is sealed off there is a pipe which ends out. So this is not necessarily a leak. But it is important that you check the compressor motor speed, check the gas pressure within- pumping pressure to be checked - before the problem of a leak can be ascertained. Also if there is a leak then you need to pressure test the sealed system including the compressor before gas is filled.
Take help and estimate before you decide or a new fridge would be cheaper.
May 03, 2011 | Refrigerators
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Gas leak no solution refuse to pay rx 6000 when it is in the warranty period t
Actually, all air conditioners having compressor warranty for 5 yeas and comprehensive warranty for one year only. If your a/c under gas leak during comprehensive warranty period, you have rights to ask the manufacturer/supplier to do free gas charging. Check your warranty details and date of purchase.
Dec 13, 2010 | Heating & Cooling
Lookin to buy used 99 accord nd 30 day warrenty since I will not buy as/is. what should i pay for 30 day
Zero!  If you are paying what the dealer is asking for the car, they can throw in a 30 day free of charge.  If not, I would buy elsewhere.
Nov 12, 2009 | 1999 Honda Accord
Servicing charge
Sorry to hear of your troubles, but you 've somehow posted them on a do-it your self wbsite, from the intent of this letter i would assume that you would have liked to post it somewhere else.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do i get a replacement deep fryer
http://www.rivalproducts.com/help.aspx?helpNav=1
Warranty Coverage
Limited 1 Year Warranty
Rival warrants this product to be free from defects in materials or workmanship for one (1) year from date of original purchase. If you have a claim under this warranty please follow these procedures
  1. Within the first 45 days from date of original
  2. purchase, defective product should be returned to original place of purchase for replacement (with proof-of-purchase).
  3. Within the first 12 months from date of purchase Rival will repair or replace (at no charge) the defective product if it is delivered freight prepaid during that period to an authorized service station.
To obtain warranty services write to:
Jarden, Direct to Consumer
303 Nelson Ave
Attn: RETURNS
Neosho, Mo 64850
Proof of purchase is required when requesting warranty service – SAVE YOUR SALES RECEIPT. This warranty is extended only to the original purchaser and does not apply to commercial use, unreasonable use, or to damage to the product (no resulting from defect or malfunction) while in the possession of the consumer. Rival disclaims all responsibility for consequential, incidental, or commercial losses caused by the use of this product. Some states do not allow this exclusion or limitation of incidental or consequential losses, so the foregoing disclaimer may not apply to you. This warranty gives you specific legal rights, and you may also have other legal rights which vary from state to state.
Nov 11, 2007 | Rival CF153-WM Deep Fryer
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
