Question about Microsoft Zune JS8-00001 Digital Media Player
Change musci on Zune
1. I just got my Zune 80G back from my son and want to delete all of his music from it before I sync it up to the computer and add all of my music which I have moved all to my music on the computer. He lost all of the paperwork so I am lost in how to do that, there seems to be no "reset" button.
2. Once my music is loaded do I have to keep it on the computer under "my music" as I normally like to keep it only on my external hard drive?
  • 8,596 Answers
Documentation is available from zune website - use Windows Media Player to delete songs - click on song name and press "delete"; you do not have to keep it in "My Music," but you must manually go in and change the configuration in Windows Media Player to search for the new folder on the external hard drive IF the external is permanently connected to the computer - otherwise, you will not have to alter the configuration
Posted on May 26, 2008
I can not connect my cell phone to my PC computer. when i connect, it asks me must insert driver first
you must use zune to connect it
below explanation about zune :
Zune software is required to get your music, videos, and podcasts from your computer to your phone. It is used to sync music, videos, pictures podcast etc. between your computer and phone. If you don't have the Zune software installed on your computer, go to www.zune.net to download and install it.
How to Set up Zune to sync your computer and phone?
1. Connect your phone to your computer using the USB cable.
2. Zune automatically opens on your computer, if you haven't opened it.
3. Wait for Zune to recognize your phone, and then follow the onscreen instructions to Set it up.
Dec 25, 2010 | HTC HD7 Cell Phone
I left for 3 months and shut down my zune when i got back i started it up and it said all my music was missing and it would shuffle threw the songs not playing them and so i hooked it up to the computer...
heres how u fix that problem hook ur zune up to ur computer and manually delete all your music on ur zune and then sync all of it back on after its done the problem goes away
Aug 28, 2010 | Microsoft Zune JS8-00001 Digital Media...
Can't put music on zune!
1. Sync the Zune with its "home" computer. Each Zune has a specific "home" computer that it automatically syncs with. Use your Zune-specific USB cord to connect your device to this computer, and then sync your device as you normally would. This will solve most software hiccups and will generally get your Zune out of a "frozen" state.
2. Perform a soft reset. If syncing your device doesn't work, you can reset your software by holding the "Back" and "Up" buttons on the central control pad. Your screen will flicker, and then the Zune logo will appear with a status bar. Within a few moments, your software should be returned to normal.
3. Perform a system restore. However, doing this will erase all of your music, videos and photos, so only do this if you have exhausted both of the other troubleshooting steps. You can restore your Zune by connecting it to your computer, selecting it from the "Devices" list, and then pressing the "Restore" button. The process may take a few minutes, depending on how much content you had on your device. Once the restore has finished, your Zune will be completely blank.
Sep 30, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
How can I sync music onto my zune 120GB without using zune softwa
the problem with the zune is that its own by microsoft and you cannot sync music without the software however there is a zune forum that you can check out for advice on how to use the software better.. zune.net then check out the forums
May 11, 2009 | Microsoft Zune JS8-00001 Digital Media...
Can't move music from Zune to new computer
No. You cannot take music off your zune and put it on another computer. You will need to copy your music files found under My Documents, My music, zune. put it onto a large flash or external drive. Then install the zune software onto the other computer i havent done so already. Take the files you copied and paste them back into the zune folder on the computer. You might have to reauthenicate music that you have downloaded. Just log in and it should be fine
Mar 03, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune software
Try to format the hard drive of your MP3 player then install the software needed for your MP3 player and copy new song to your drive.
Jan 01, 2009 | Microsoft Zune JS8-00001 Digital Media...
Music stops and zune freezes up
uhm i think i may have found your solution, that is if your using limewire or some client of the sort, i synced my zune while the program (limewire) was on and downloading music and i had the same problelm you did so i simply deleted all my music and put it back on the zune while limewire was off and now it works fine, i have an 80 gig btw if that matters
Feb 10, 2008 | Microsoft Zune JS8-00001 Digital Media...
Deleting movie when connect to charge
It will delete the stuff because it is monitoring those folders for content. When the content disappears then Zune assumes you no longer want it.
Try this-in the Zune program set it to not autosync. See if that stops it. It worked when I tried it with videos but not when I tried it with music.
Otherwise be prepared to keep all of the music and movies in the folders that Zune monitors.
If space on your computer is an issure, I would suggest adding an external drive.
Jan 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
71 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
