Question about Refrigerators
Our refrigerator seems to be working but the temperature is not as cold. Eg. ice cream is soft and milk is warmer. We moved the temperature setting as high as they would go but it only makes a slight difference. Thanks for your thoughts.
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerOur refrigerator seems to be - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning RefrigeratoOur refrigerator seems to be - 2_bing.gif"http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 07, 2010
Not keeping ice cream cold enough in freezer & milk and drinks in refrigerator are not cold enough
You need to change the settings on the thermostat. Its a dial setting inside or digital setting on the door. Lower the temperature until you are satisfied.
Feb 29, 2016 | Refrigerators
Ice cream is soft, but peas carrots and other such things seem hard. Could be the defrost is on all the time? Moved temp to the #9 setting and ice cream is still soft. Makes a noise as if the defrost is...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
heatman101
Aug 26, 2010 | Maytag MTB2176 Top Freezer Refrigerator
What setting between 1-9 should I set Freezer to prevent freezer burn
Good day,
Freezer burn is due to too cold a temperature in the freezer compartment. Nominal for that machine is 4 to 5.
However only time will tell you what is acceptable, since freezer burn can occur even at a warmer setting, if the product is stored a long time.
1 is warmest and 9 is coldest. I would lean to a slightly warmer setting to start off but that will create a trade off, since it would reduce the speed of ice production, and with especially high quality ice cream, possibly ice cream being too soft.
Patience is your friend here. But what you want is there.
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice maker is making 1 tray of ice a day
There are 3 things needed to make proper ice.
Water, cold, time.
Check the cubes that are being made, they should be the same size crescent shaped. If they are not solid and some are hollow or broken then you are not getting enough water to the refrigerator. This is usually caused by the little valve on your house piping that connects to the refrigerator being plugged with sediment.
If the the cubes are all solid and the same size check the temperature of the freezer, it needs to be below 10 degrees F and works best below 5 degrees F. If it is warmer than that it will only produce ice on a very slow schedule. If you do not have a thermometer ice cream is a good indicator of temperature. If ice cream is hard the temperature is below 5 degrees F, if it is soft you are not cold enough to make ice cubes either.
If all this checks out alright you may need to have the ice maker replaced. the modular ice makers are available for sale at most all part retailers.
Apr 19, 2010 | Kenmore 74822 / 74824 Top Freezer...
Freezer was freezing ice cream rock hard and refrigerator liquids( ie. milk, beer) was only a little cool. how should i adjust the number settings?
Don't do anything too quickly here. Move the freezer number one digit warmer and fridge one digit cooler today.
Check temp (and icecream) tomorrow. If not satisfied, move one more digit on the freezer or fridge until you are happy.
Mar 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer is no longer keeping ice cream solid/frozen
Ice cream is usually kept at -10 degrees to stay firm. Need to check temperature. Look at condenser coil for cleaning. This is usually the most simple and common issue. If not making the desired temp, and the temperature control is set for that temp, and compressor run constant, it is a refrigeration issue. If compressor does not run constant, then a control issue.
Jan 24, 2018 | True GDM-49FC Refrigerator Commercial
Model #PSC25MSTA SS - one year old, never got a manual with refrigerator, don't know how to lower the temperature. suddenly, ice cream melting; milk sour; push buttons to lower temperatures, does not set a...
Had a problem similar to this with this frig and the problem was a bad mother board that kept the fans from operating correctly to disperse the temperature. I woould actually get stalagtites forming from the warmer top shelves to the colder lower shelves. Repaire under extended warantee.
Jan 11, 2010 | GE Profile Arctica 25.4 Cubic Feet...
On top freezer works fine, fridge compartment below is not cold.
turn the dual temperature switch to warmer for the fridge to cool down.
Apr 04, 2009 | Refrigerators
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Soft ice cream
there are vent openings in the back of the freezer you should not block that ..it will cause the temp to go up
Jan 21, 2008 | Kenmore 72073 Top Freezer Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
