Question about Zhone Computers & Internet
I have a zhone 6381 a4 modem in bridge mode and i want to use the port forwarding feature on it but it comes up with an eror when I try and save it. Can you help me with this problem.
    Scholar:
  • 104 Answers
Can you not contact your router manufacturer,they will advise you.
Posted on Aug 07, 2010
Ok, I have a Zhone 6211-I3-200 Bridge/Router or in other words a Paradyne ADSL CPE, and I cannot for the life of me get it to work with my Xbox 360. I used to have a different router and I would switch...
Zhone Modem Model #. 6211-13-200-0PA ADSL2 BRIDGE/ROUTER, AN.
I would like to upgrade current Firmware, but it is quite difficult and my ISP support even knows how to do this upgrade.
Nov 06, 2011 | Zhone 6211-I3-200 Router
I have a Zhone router, model number 6218-I4-200-0CL. I'm trying to figure out how to forward a port, but there is no actual "Port Forward" option under the configuration options. There is...
Hi!
Please follow the guide here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Mar 17, 2011 | Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM...
Hello there, need to know how to config a phone line modem Zhone 6381 I guess its called the Zhone 6381-Ax Router. I happen to prees the reset button and losst the programed IP. how can I go about...
To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address (192.168.1.1) into the Location field of your browser and press the Enter key. The following screen appears.
The default user name is Admin and the password is Admin. Both are case-sensitive.
Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
The first screen that appears after the log in screen is the Home page.
From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
From here, go to the Setup Tab and click the New Connection on the left.
Input your numbers and don't forget to save.
Hope this helps!
Dec 21, 2010 | Zhone (6218-I2-200) Router
How to enable upnp with zhone router
hello, this picture should help ya.
http://screenshots.portforward.com/Zhone/6381-A4-200-1PR/UPnP.htm
Jul 31, 2010 | Zhone (6218-I2-200) Router
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
I'm having problems setting up my Panasonic BL-C131A Network Camera to access them through the internet. I have a Zhone 6211 DSL Modem connected to my wireless broadband router. I can view the cameras on...
Maybe you can try to check your fire wall setting,sometime antivirus is blocking your camera through internet access.you can add your camera for exemption for blocking in the iternet.
Feb 27, 2009 | Computers & Internet
Port Forwarding with BR-6104K
hope this helps
In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
I have not run into CABLE providers cable modems having to do this
did you allow that port in your computers firewall?
Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
User manual: http://www.edimax.com/images/Image/manual/Wire/BR-6104K/BR-6104K_M.pdf
instruction site
http://portforward.com/english/routers/port_forwarding/Edimax/BR-6104K/ICUII.htm
to test the port connection you can go to http://whatsmyip.org on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
Mar 29, 2008 | Edimax BR-6104K Router (br6104k)
Help plz!
Connect your computer directly to the ethernet port on the Modem. Bring up a command prompt window (you can get one easily by going Start > Run and typing "cmd" and hit ok. Then in that window, type "ipconfig /all" and look for the Gateway IP Address... type that Gateway IP into your browser address bar and log in from there. Once you get in, the setting should be pretty easy to find. Check out http://www.zhone.com/support/manuals/docs/62/6210-A2-GB21-10.pdf for more details.
Sep 08, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Computers & Internet Logo
356 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Awesome12
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
