FRIGIDAIRE AFFINITY LTF600 FSO PUMP KEEP,S RUNNING AND WONT SPIN
I fixed mine by replacing the door lock they are about 50.oo
The door lock has two locks, one is instant when you push start the other is a time lock, so you cant open the door for a little if you stopped it during the spin cycle. The problem is what they call the WAX switch or heater. When power is applied to this WAX lock it takes 30 to 60 sec. to lock and to unlock when power is removed.
The machine will not spin, if this lock is not working correctly.
You cant bypass it by jumping the power from one side of the shitch to the other. The board moniters the power draw and when the switch closes the lock contacts. You can how ever open up the lock very easy and bend the contacts closer to get you by for the weekend. unplug washer, remove the two screws on the back of the top panel behind the washer, remove top, open front door and remove the two screws that hold the lock, reach in an pull up the lock, remove wires, now open up lock and bend the piont contacts in side or install new switch.
Posted on Aug 16, 2010
  • Washing Mach... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineFRIGIDAIRE AFFINITY LTF600 FSO - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing MaFRIGIDAIRE AFFINITY LTF600 FSO - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 07, 2010
Why my frigidaire affinity wont spin
Good Afternoon Iliana, thank you for allowing me to assist you!
If your washer does not spin, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Dec 14, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer ATF6000 will agitate but wont spin
Hi burwellkaren - Is the washer making a humming noise? If so, either the drainage hose or pump is clogged and needs cleaning. If not, then the unit may possibly be experiencing an issue with the control board not communication correctly, faulty pump, timer, door lock assembly or something more severe like a damaged tub. I will personally recommend contacting a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 08, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
My frigidaire affinity washer doesnt spin during the rinse cycle.
Hi javierc569,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Jul 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front loading washer
Any E20 code means your washer doesn't drain.  More than likely there is a screw, nail, coin, bobby pin, etc locking up your pump and causing it not to drain.  Keep in mind that your washer has a 1 yr warranty but some service companys will charge for this kind of repair because it is not technically covered under warranty.
Aug 21, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
