Question about Baby Gear
'76 CJ-7 w/360 4b v8
How do I find the serial numbers on the engine & transmission so I can buy parts?
My problem was solved by the assistance of Nitrotrike. Thank you.
Posted on Apr 28, 2008
Where do i get the engine serial number for jeep cherokee v8 2000 model petrol engine
this is only covered in the Real FSM. book
first chapter. in fact.
Identifying engines.
page 62 , under ENGINE chapter
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
even shows photos.
4.7L
front ,right block,
just to right of #2 (right) front freeze plug, bingo
Feb 11, 2015 | 2000 Jeep Grand Cherokee
Tip
All nokia secret codes part6
 Call number transmission * 31 # - { CLIR - Calling LINE identification Restriction switches on for the general call number transmission }
# 31 # - switch off the general call number transmission
# 31 # [ telephone number ] - with the next call suppress the own call number (thus temporary)
* 31 # [ telephone number ] - with the next call transfer own call number (thus temporary)
* # 31 # - status query (of call number transmission)
# 31 * [ telephone number ] - own call number show, although receiving station switched call number suppression on. (is not usually de-energised of the Netz(betreiber).)
* 30 # - switch { TIE-clip - Calling LINE identification presentation for the announcement on of the call number of the caller }
# 30 # - switch off
* # 30 # - status query
This also partly goes with 6600 via Men: Attitudes - calls - own No. send...
The following codes are not supported by most Netz(betreibern):
* # 76 # - announcement of the call number, under which one reached the calling (not its call number during rufumleitung!) { COLP - COonnected LINE identification presentation }
* 76 # - switch on
# 76 # - switch off
* # 77 # - announcement of the call number, under which the caller reached me (not my call number during rufumleitung meinerseits!) { COLR - COnnected LINE identification Restriction }
* 77 # - switch on
# 76 # - switch off
on May 12, 2010 | Cell Phones
What year is a model 76 jiffy ice auger
The model 76 ice auger was made over a number of years and is probably still be in production. If it has a Jiffy engine, it was made before 2011 ("2500 series"). If it has a Tecumseh engine, it's 2011 or newer. Your best bet for getting the age is to find the serial number on the auger or the engine and contacting the manufacturer. Info source: http://www.jiffyonice.com/EComStore/pages/operatingmanuals.aspx
Feb 11, 2015 | Refrigerators
Whats is the serial number o model for kit cluch gran vitara 2002 2.0 4x4 4 cil?
kit cluch?
serial, are you asking where the transmission serial number is
(its top of bell rear)
or part numbers for clutch parts?
first tell us the JOB, then ask a question?
if you need parts, you need to tell country first, we can not guess that. in the USA we have any autostore (napa best) for parts.
or the USA 4 online stores, here, (decreasing due to chapter 11 status in usa)
see Garden Grove here. (this page is G16 engines, but sources are the same)
http://www.fixkick.com/buy-parts.html
Jan 24, 2015 | 2002 Suzuki Grand Vitara
What is serial number CJ-818A on yamaha acoustic guitar, its the A i CAR`T FIND
Well the "A" just refers to a sub model of the Yamaha CJ-818 (which is the model of the guitar). What is the location of the second number you listed? You might look inside the soundhole and at the butt of the neck to see if the serial is there.
Apr 27, 2014 | Yamaha Electric Guitar
I have 2005 Jeep grandCheroke V8 the dash light say Transmission over heating
i probably is.
use a pyro IR gun and check it real temperature
first make sure engine is not overheated
or the ENgine Rad, at bottom is not full of rust mud.,making tranny cooler useless
were you pulling a huge load?
Aug 20, 2013 | 2005 Jeep Grand Cherokee
Transmission serial number for 1994 dodge shadow 2.5 liter engine
The serial number on any part is unique to that one part, there is no way to look up a serial number. Are you sure you don't mean the part number?
Feb 12, 2012 | 1994 Dodge Shadow
302 v8 on a 76 ford bronco just rebuilt has
sounds like your timing is way off,if no timing gun and you dont have specs,loosen your distributer a bit and rev your engine to about3000 rpm and just listen to the engine while you slightly turn the distibuter until it is the smoothest sounding with no sputtering then tighten your distributer back up or pay the bucks get it timed at a shop its cheap
Oct 19, 2009 | 1981 Ford Bronco
Model MAH4000AWW door leaks. Has hole worn in it.
You will need to go back to your madel number. Look you a series or rev number. 10, 42 or 53. It will have one of these numbers there. This will tell you which part your looking for.
model-number-tag.jpg Please rate solution if helpful. Thanks
Aug 24, 2009 | Washing Machines
Serial numbers?
May I call you? or you can call me at 314-691-0812; Bob.
The spindle,(I believe) is what I need,but can't find exact part to buy in catalogs. I need the part #, or something to be able to buy trans. filter and gasket. If that helps.
Apr 27, 2008 | Jeep 10 x 20
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
