Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Normal light is flashing and dishwasher will not start up. Whirlpool model #GU2500XTPB3
SOURCE: flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Posted on Sep 22, 2008
  • 188 Answers
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
SOURCE: **My dishwasher normal light keeps blinking**
I have the same problem. I have tried turning off the breaker and the door seems to be locking, but still won't work. Any other suggestions?
Posted on Dec 13, 2009
SOURCE: Green Lights flashing, Whirlpool D/Washer not responding
Well I contacted a couple of techy guys I know and they were not familiar with the dishwasher. I then called the outlet we had purchased from to see if they could refer us to a service technician. I explained what I wanted and the woman on the phone asked what the problem was - she then asked me to close the door of the dishwasher and hold down the start button for 30-40 seconds to see what happens, which I did. At about the 30 second mark the machine started. She said it was likely that someone had interrupted the last cycle and we had effectively reset it. It ran a further 30 seconds to complete that last part of the interrupted cycle and has been fine ever since. My wife took them a box of chocolates the next day. Shows to go ay? Kind regards Peter
Posted on Dec 30, 2009
I have a whirlpool quiet partner II dishwasher model # DU1055XTVB5 and the normal light is steady flashing I have did the sequence to reset HEATED DRY NORMAL HEATED DRY NORMAL and the normal light...
Angelia:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 06, 2018 | Whirlpool 24 in. DU1055XTP Built-in...
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Won't run - normal light flashes
When I had this problem, it turned out to be the heating element.
Jul 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Normal cycle light flashing
If its the ormal led flashing that is normally caused by a stuck key ing the key pad. Might try unplugging and plugging back in but sounds like you need a new touchpad.
Mar 11, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
press and hold the start button until it resets about 5 sec then try again.
Mar 01, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
62 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
