Memory Card Drive
When I put my memory card from my camera in the slot nothing happens. I hear a ding, put nothing pulls up.
  • myboxertaz77 Apr 27, 2008
    i don't have a drive e, f, or g...i don't know where to find them....i have a memory card in the m computer window...i am running windows vista premium...i have looked everywhere to find something....still don't know what to do
    Genius:
  • 1,019 Answers
You need to ensure that your Computer has the relevant Drivers Installed. i.e Toshiba Laptops have a specific Driver, Solely for MSSlots, 1 as the program, and another program to Format.
Also check that the memory card, appears in the My Computer Window, As Drive E:/ Or F:/ et,c. assuming that C:/ would be your hard-drive. D:/ Or D:/ And E:/ CD/DVD Drives. Then any additional devices such as F:/ G:/ H:/ I:/ et,c will be card-readers et,c.
Finally is that the computer understands the Actual Format of the SD Memory Card. FAT/FAT 32 et,c.
Hope this points you, towards solving your problem.
Mike @ Compurepair.
Posted on Apr 27, 2008
  • Mike Waldron Apr 27, 2008
    it does,nt help to rate a solution, before the expert that assists you to resolving your problem.
    initially you never mentioned your operating system, as being vista.
    if you,d have read my possible solution, you,d have read look in MY COMPUTER. for drives other than hard-drive C:/ Or DVD Drive D:/ Or E:/.
    Should you be fortunate enough to have another expert Offer you FREE Advice, on how to resolve your problem. I,d advise you not to rate their efforts, until your problem has been resolved. by doing so you are degrading the experts statistics.
    Good Luck. Mike @ Compurepair.
Canon PowerShot SD790 IS Digital Camera
Sounds like two things are happening here. You may be putting the card in improperly...check the manual to see if the card should be face up or face down. Also, be sure the slide switch on the side of the card is in the unlocked position.
May 14, 2010 | Canon PowerShot SD790 IS Digital Camera
Have a Nikon D70, tried to load the memory card into the slot, and the grey button doesn't pop out when the card is put in the slot....the card wont go the whole way in
If there is nothing obstructing the slot, and you are inserting the card correctly, check the sides of the memory card to see if they are not damaged.
Jan 29, 2010 | Nikon D70 Body Only Digital Camera
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Aug 04, 2009 | Canon PowerShot A720 IS Digital Camera
How do you transfer pictures on thememory card inserted in the print to the computer?
if you plug the memory card in the slot. software will see it and start automaticly.
May 30, 2009 | HP Photosmart C4480 All-In-One InkJet...
Kodak EasyShare cx4310: 3 fast dings when connecting the usb
Hello I don't believe you have a problem with the camera or the cable. It sounds like the drivers are not working properly. Here is a link you can use to download the driver for your camera. Below are the steps:
http://www.kodak.com/global/en/service/downloads/dln_ekn027990.jhtml?pq-path=1211
1 Choose your operating system
2 Hit the download button
3 Hit download on the new page if you have a pop-up blocker
4 Select Save
5 Locate the file, double click and hit run
6 Follow on-screen instructions
If this fails, you can always remove the memory card from the camera and plug that into your computer(if you have a slot), if not, here is a link to buy some:
http://shop.ebay.com/items/?_nkw=external+memory+card&_sacat=0&_trksid=p3286.m270.l1313&_odkw=memory+card+slot+external&_osacat=0
Hope this helps
-Chris
May 01, 2009 | Kodak EasyShare One Digital Camera
Switched on pc monitor says no signal? The fans and hard drive are spinning but nothing happens ive tried putting xp disc in but thr drive flashes a couple of times then stops.How can i start my pc or cant...
check the memory card, or the ram?! removed the ram ram from the slot? clean the slot of the ram and clean also the memory card by an eraser?!
check also the video card?!!
Feb 26, 2009 | ASUS P5VD2-MX SE Motherboard
I inserted my memory card from camera but nothing happened.
What type of memory card do you have that your trying to insert.
Jan 15, 2009 | HP PAVILION A6230N DESKTOP PC
Laptop
are u sure that the SD card fits in the slot perfectly and doesnt come out?which SD card is it,is it a MINI SD or MICRO SD? because for these two u must use SD CARD ADAPTER.. only then the card will sfit in perfectly. Also when it is inserted properly and it fits in then u will hear a DING sound in ur laptop whether ur running VISTA,XP or ne other OS and also u can see the Memory card as the "name" of the card or as "REMOVABLE DISK" in "MY COMPUTER".Please confirm me with this step and ill help u out furthur.
Oct 04, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
