MY 90 WERIES KENMORE WASHING MACHINE FABRIC SOFTENER DISPENSER DOES NOT EMPPTY
  • 3 more comments
  • balkodm Aug 18, 2008
    I have the exact same problem - any solutions out there?
  • bsiprelle Oct 20, 2008
    My series 90 has the same problem. While running, (not sure which mode) I can occasionally see the water in the dispenser "disturbed" due to water being pumped into it but it never drains. I had the case or cabinet removed for another reason so I took the dispenser out. It has a small integral tank attached where two hoses attach. The funny thing is, the hoses are at a level that is higher than the dispenser. Fluid can go into the dispenser but there is no physical provision for it to drain. I don't get it. Usually, I'll look at something long enough & figure it out. Not this thing! Help!
  • lovethespurs Nov 23, 2008
    I have this washer for 7 years and it has been a wonderful one. The fabric softener will not dispense lately and I cannot figure out what the problem is.
  • wash-n-wait Dec 29, 2008
    We have the same problem.  The fabric softener dispenser does not empty.  We've had the machine for several years and we have noticed this problem for the last 2 months.
  • t_kduncan Feb 03, 2009
    I have a maytag neptune and the liquid softener doesn't drain either. I've had the washer 3 years. Darn it.
I am having the same issue. I do know that the reason you don't see any physical provision for it to drain is because it is drained using a siphoning effect. water is put on top of the fabric softener until it reaching a point where the siphoning begins. Once the siphoning begins, the whole thing will drain out until there isn't much left (however there will always be a little water left). I know siphoning works with my drawer b/c when I take it out and fill it with water slowly until the siphoning begins, the whole thing drains out. There must be another reason why the fabric softener isn't working.
Posted on Jan 12, 2010
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
My fabric softener dispenser does not release softener
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Oct 09, 2010 | Kenmore Washing Machines
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore washing Machine Mod. 11020052994 will not wash on heavyd
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Kenmore Washing Machines
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Oct 10, 2008 | Washing Machines
HE washing machine
As you look at your dispenser. The Left compartment is for Detergent. The Right Front compartment is for the Fabric Softener Liquid. The Right Rear compartment is for Chlorine Bleach.
Jul 27, 2008 | Kenmore Elite 45986 Front Load Washer
MY 90 SERIES KENMORE WASHING MACHINE FABRIC SOFTENER DISPENSER DOES NOT EMPPTY
if agitator mounted pull off ..may be blue ring at base if so pull up and lift dispenser off or newer type twist off..soak in hot water and flush out if front mounted dispenser clean as good as possible
Apr 27, 2008 | Washing Machines
Washing Machines Logo
455 people viewed this question
Top Washing Machines Experts
