Question about Reebok Exercise & Fitness
Rebox i run tread mill.Belt moving but if you put weight on it the belt it stops running.
    Champion:
  • 218 Answers
Drive belt is bad and needs replaced
Posted on Aug 13, 2010
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
The tread belt moved to one side how do I fix ir
HI,
Check the following video to know how to align the treadmill belt which is going to one side. All trad mills have the same procedure to align the belt.
Ajin
Jan 18, 2012 | Epic View 550 Treadmill
Belt stops when placing weight
the belt in side the hood may be too tight. or the tsc may be set too low so take a small flat head after you remove hood and on the mother board should be an adjuster turn it while tread mill is safley position and turn it slightly
Jan 15, 2012 | Reebok Exercise & Fitness
I have a NordicTrack c2200. I find that the tread belt is not running smoothly while running on it. As I run, the belt temporarily stops during each running step, causing me to trip up. I tried to lube,...
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
Dec 30, 2010 | Nordic Track Exercise & Fitness
My tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Apr 10, 2010 | Proform Exercise & Fitness
When weight is put on belt it stops. works fine by itself at all speeds
If you can stop the belt. You need to be aware that both running & drive belts can cause the same problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | Proform Sport 1000 Folding Treadmill...
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
129 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
