Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
The spin drying is not drying properly so there is alot of water in the clothes
  • Westinghouse Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinethe spin drying is not - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 07, 2010
5 Suggested Answers
  • 148 Answers
SOURCE: clothes dryer
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Posted on Jul 12, 2008
SearsTechToo
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
Just_Bobz
  • 448 Answers
SOURCE: spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Posted on Feb 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: Washing not spinning water out of clothes
Must be something in the pump obstructing the water flow.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
Why do I have to dry stuff twice.?
A lot of times when your dryer doesn't dry your clothes ,the problem is with the washer not spinning properly. Then there is too much water left in the clothes so the dryer can't remove it all.
Jul 04, 2014 | Whirlpool GEQ8858J Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Haier xqg50 will not dry; It runs the full wash cycle, and will actually run the dry cycle, but the clothes come out comletely soaked. Ran the full 120 minute dry cycle three times, and the clothes were...
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 11, 2010 | Haier XQG50-11 Front Load Washer / Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Jun 14, 2009 | Washing Machines
Spins fine, but clothes still soaking wet
Feb 21, 2009 | Maytag Performa PAV2200
Washer won't spin dry clothes
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
98 people viewed this question
Top Westinghouse Washing Machines Experts
Mack Baxter
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
