Question about Refrigerators
I have a GE side by side refridg that the freezer is not working.I was told by a friend it was the heater. It could it also be something else and is the heater hard to replace and is the part expensive.
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerI have a GE side - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 07, 2010
Both freezer and refridge wont get cold
sounds like your defrost heater went bad.the way you can tell is frost on freezer wall
May 07, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
I have a GE profile side by side refriderator. The freezer is working(temp is below zero on coldest setting, but the refridge is warm, ranging from 36 -59 degrees depending on the shelf. (this is on the...
the ice is caused from the frozen drain in the back. the cold coil is also frosen / this stopes the air to the fresh food .. so defrost the freezer and ck the heater and defrost termator . . you may also need the main control that has the defrost timer on it . located on the back of frig.. hope this helps . mm
Jul 11, 2011 | GE Refrigerators
The refridg part of my ge side by side stopped working but the freezer still works
HI,CHECK IF THE EVAP MOTOR IS WORKING,IF MOTOR IS WORKING ,PROBABLY YOUR REFRIG HAVE A BAD CONTROL BOARD CHECK BOTH OR REPLACED BOTH ALSO CHECK AIRFLOW CONTROL DAMPER..
Jul 05, 2011 | GE Profile PSW26P Stainless Steel Side by...
My ge side-by-side refrigerator/freezer isn't cooling. It started on the refrigerator side and now both sides are losing cooling capability. There is ice build up on the lower back wall of the freezer....
Yes that is right. Turn the Refrigerator off/ unplug it. Remove the rear panel of the freezer and thaw out the coils with a fan or hair dryer.
The most common problem is with the defrost heater. Using an ohm meter check the heater for continuity but unplug the 2 wires (one from each side). This should be a glass encased heater. you can also very gently pull both ends of the heater and if it is bad it will come apart instead of feeling "springy". If you have only one heater your new replacement will probably be a 2 heater kit.
I
Jun 15, 2010 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My GE refridge model GSS20DBMB WW freezer coils keep freezing up! I have replaced the door seals as an appliance center recommended. However, It did stop it from freezing up! we have to use a hair dryer...
Something has gone wrong with the defrost system. It could involve the defrost timer, the evaporator heater, or some of the wiring.
This problem would take some troubleshooting that most do-it-yourselfers would likely not be able to do.
Oct 18, 2009 | GE GSS20DBM Side by Side Refrigerator
My refridge is cool but not cold and my freezer is the same??
I've been replacing a lot of defrost heaters on these. is there frost inside back bottom of freezer? I've also had computer board problems that cause the freezer fan or the fan by compressor to not run...the coils next to compressor are very easy to get dirty and stop up and cause overheating also..check these and see if one of them is the problem :)
Jun 13, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE Profile Energy Star Refridge...
brookid, first you want to start with the basics; door seals are good, light turning off with door closed, dispensor duct door closing all the way, condensor coils cleaned, evaporator fan and condensor fan are running. If you are satisfied that there are no problems here then you want to see if you have a heavy frost build-up on the back of the freezer panel. If you do, you have a defrost issue that usually involves the defrost heaters, main board or freezer thermistor. Tests will have to be made on the main board to determine these. If you don't have a frost build up, you need to check the airflow vents from the freezer to the refer compartment. I will attach a photo of a refrigerator with a defrost problem. Catriver...post back.
Sep 26, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
