Question about Kenmore 67872
I have a 3 year old kenmore top freezer (model # 253.67872508) that seems to stay in defrost mode to long. To the point where the milk in the fridge is at room temperature. Three hours after I noticed everything was getting warm it started working again.What is wrong with this refrigerator?
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
  • 351 Answers
SOURCE: Fridge and freezer not cooling
this should be under warranty... check to see because you have a big problem. you know how to get the back of obviously let it run take the back panel off the freezer and pay real close attention to where the frost ends on the coils i bet you are low on freon and or the compressor is bad....
Posted on Apr 24, 2009
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
SOURCE: I have a 19-year-old Kenmore top freezer
You might be developing an ice dam in the bottom tray of thr freezer that is obstucting the flow of cold air to the refigerater part of the unit. remove frozen items so you can see the bottom tray and see if you notice an exccesive amount of frosting on said floor tray, if so you are probably experiancing a defrosting problem.Check to see if you can feel cold air coming in from the top back section of the refrigerator. There is a fan that blows across the coils in the freezer section under the floor tray, if you cant feel the air either your fan has quit or you are froze shut.You can try a temp fix by removing food items to a cooler with ice or another unit and unplugging this one and letting it thaw out, be sure and put down a towl or two on the floor the tawing ice will go to the evaporater tray underneath and overflow once its thawed plug it back in and let it cool down. Check again to see if you can feel air in the frig. if you cant your fan has quit, you need to seek local appliance tech help they should be able to get you going for a fairly inexpencive amount.
Posted on Jul 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore model 253 71132105 freezer works fine but
MGPRICE Just have the answer right in front of you and nobody gives you a thumbs up! I did. This person was even smart enough to include their model number! thumbs up to them I just am curious why they never responded. Sea Breeze
Posted on Aug 09, 2009
I have a whirlpool freezer on top with ice maker the freezer is working great but my fridge is not cold my milk keeps spoiling & nothing stays cool
Sounds like a defrost problem. Three things can be wrong... Defrost heater, defrost timer or defrost thermostat.
Jun 03, 2014 | Refrigerators
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
I have a 7 year old GE refrigerator (top mounted freezer) that seems to stay in defrost too long-- everything in the freezer defrosts, the ice cubes start to melt, the ice cream gets soft, etc. Food in the...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer problem (icing behind cover inside of freezer)
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Kenmore 67872 Logo
115 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
