Question about GE Cordless Phone & Answering Machine 27931G
Will the answering stop working when the battery is dead in the handset
  • 370 Answers
No,This wont happen.The answering in connected only to the base unit.Answering system and the battery of handset is no way related.
Even the battery is dead the anwering machine will work.
Thank you
Posted on Aug 07, 2010
2 Suggested Answers
  • 508 Answers
SOURCE: Unide TRU9485-2 handset goes dead after answering. new batt.-same
clean contacts with qtip and rubbing alcohol and bend out!!!! :)
Posted on Jul 07, 2009
All 3 handsets seem to be dead at same time. It seems odd that they would all go out at same time. Is it simply a battery issue? The answering machine part works fine.
Check the line using an old conventional plug in phone. You should always keep one for power cuts. Also, get someone to phone your number.
One a three handset system, the signal to all three are driven by the main unit, the bit with the answering system. Check that is plugged in to the mains wall socket and if it is, check for power at the socket. If that checks out, you need to check that little plug in power supply unit. Best way is with a test meter. If the lights are on on the unit and the answer machine works, then you know you have power at that unit, so you need to check the power supplies in the slave units.
My guess is that your line is dead to the house.
Dec 23, 2015 | Lands Phones
Both handsets have gone dead
Sadly that does happen tho not often .
Nov 14, 2015 | BT 4500 Cordless Phone - DECT - Satin...
My phone isnt coming on but the base is on charge
More often than not, this is simply due to dead batteries - do you know how old the batteries in the handset are? if they are quite old it might be worthwhile replacing them with the correct type of batteries (please ensure they are the correct type otherwise you can cause a fire putting non-rechargable batteries in a rechargeable phone) as this usually fixes the issue.
One other question, has the handset been dropped lately? This is another usual problem for a handset to stop working so ask whoever uses it and hopefully you will get a truthful answer :)
thx, if this helps please rate :)
Jan 28, 2011 | Uniden Cordless Phone
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Sep 29, 2010 | Panasonic Lands Phones
Uniden 5.8 PowerMAx phone batteries are a pain in the axx! All 5 handsets dead within 2-5 minutes. Replacing the batteries will not resolve the problem. The only resolution is STOP BUYING UNIDEN...
Try putting the handset in the main unit and see if it will fully charge. It may very well be a problem with the individual charger, not the handset batteries.
Jun 24, 2010 | Uniden TRU8885 Digital Answering Machine
Jul 07, 2009 | Uniden Cordless Phone
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
We have BT Studio 1100 with three handsets. From working well, they all became dead. We have changed the batteries. The phone line is working, and there is electricity reaching all the cradles which...
I have the same phone but with two handsets. Incoming calls only ring on the base and I cannot answer or make calls as the handset is permanently flassing "base 1". I have tried disconnecting and reconnecting. Also tried to restart setup but this is showing unavailable although I can still access the phone menus.
Jul 01, 2008 | Lands Phones
Handset for ATT 5.8 GHz Cordless Telephone Model 5870
i have at & t 5870 cordless phone it is no t working. handset is dead i change the battery but still not working .please give some advice.
Mar 16, 2008 | Lands Phones
GE Cordless Phone & Answering Machine 27931G Logo
81 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
