Question about Hampton Bay 24002 Ceiling Fan
Fan switch chain broke.
How do I replace fan switch?I do not know the model of the fan
  • aeronut May 01, 2008
    The chain broke on my daughter's Hampton Bay fan also. I know how to
    wire it but can't find a replacement switch. The switch is not just a
    generic on that you can get from the hardware store, the internal
    contacts are different.
  • 20 Answers
There are two types of switch for Hampton Bay fans.
One is a single-layer switch, which has all four holes on one level.
The other is a double-layer switch, which has holes in two circles, one on a higher level, and one on a lower level.
Whichever type your fans has, is the type you need to get as a replacement. Be sure to mark the old wires before removing them from the old switch, so you'll know where they go in the new switch.
I hope this helps! If you have any other questions, please feel free to ask!
Posted on Jun 17, 2008
How do I check to see if the motor is bad on my ceiling fan?
You bought the wrong switch. Just because it looks the same on the outside doesn't mean it's the same on the inside(switch). I don't know if you have a bad motor but it is a cheap low-end fan only made for Home Depot!
Apr 28, 2016 | Hampton Bay Dryers
How do I replace the 4-wire fans speed control in the Heritage 5ALW52PB3P with a 3-wire speed control?
You have to replace the switch. You cannot open & fix. First, write down which color wire goes into which slot on the switch. Each slot should be marked, usually L,1,2 & 3. DO NOT CUT WIRES. I don't know this fan so you'll have to get a switch where you bought the fan. Otherwise, I need to know how many wires on your capacitor & which slot on the switch they go into. Remember, just because a switch looks the same on the outside doesn't mean it's the same on the inside. fanman9952@aol.com
Sep 15, 2014 | Dryers
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
The chain came out when i went to turn it off. now i can't start it.
turn power off to fan, and replace the pull chain switch. you can buy a switch at any hardware store. but take old one to get the right one for your fan. sometimes wal-mart may have one. good-day ! maybe the chain just broke. if this is the case, then just replace the chain if need be.MAKE SURE POWER TO FAN IS OFF WHILE CHANGING SWITCH !
Jul 11, 2011 | Monte Carlo Fans Indoor Ceiling Fans
Fan chain broke and i want to put it back together
If the chain broke from inside the fan you will need a new switch $6 at any home improvement store and if its just the chain links you can buy a another replacement one. Make sure you tell them which switch is broken, fan or light so you get the right one and how many speeds if its the fan
May 01, 2010 | Hampton Bay 24002 Ceiling Fan
Ceiling Fan Chain Broken Off
You have to kill all power to the fan and start taking it apart till you get to the switch. There's usually just a bottom plate to remove. Sometimes lights. Replace switch and reassemble. If some chain is still connected to the switch you can add chain to it and won't have to replace switch.
Oct 04, 2009 | Dryers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
How to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
Jan 31, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 24002 Ceiling Fan Logo
195 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
