Question about Keurig B100 Coffee Maker
My model is a B66, how do you drain all of the water from the pot? I have been away for over a month and don't want to use the water that was left in the pot, I want to empty it and start all over again.
Water won't flow thru to filter or pot. Don't know the exact model but it is a 12 cup self cleaning.
Self-cleaning is wishful thinking. Every three months or so, run a pint of vinegar through it, as if making coffee (no coffee!) then flush with two tanks of water.
Mar 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
Sandy like dirt on pots after complete cycle
Do you have hard water? Sounds like hard water deposits are left on your pots. Now that phosphate has been outlawed from dishwasher detergents, the detergents don't work as well anymore. There are 2 new products that were designed to solve the problem. One in Midland and one in Tampa. Search on-line for them.
Aug 13, 2011 | Dishwashers
DCC-1200 coffee maker. I've had it for 2 months and the clean light came on. I have run several pots of vinegar, unplugged the machine overnight and reset to factory settings and still the machine...
Most coffee makers use a small check-valve in the feed line to the coffee basket and if a small particle gets trapped in it, the pumping action becomes erratic or very slow. To be sure any lime deposits are dissolved, use < 1 cup of Lime Away or similar product such as CLR. Make sure there is no water left in the reservoir and pour the product into it. With no coffee in the basket and the pot in place, turn on the machine and watch for the first drops into the pot, then turn off the machine again.
Let it stand for a couple of hours (I'd recommend against leaving it overnight) and then turn it back on to let it finish pumping the reservoir empty. Check the sediment in the bottom of the pot and if you see any 'crud' such as particles of lime or even a granule of coffee, you may have solved the problem.
If that seems to be the case, flush the machine with a tablespoon of baking soda and then clear water.
Good luck-
Jul 08, 2011 | Cuisinart DCC-1200 Coffee Maker
Keurig B66 model - "Not Ready" message when I push
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101-=-=-
May 31, 2011 | Keurig B66 3-Cup Coffee Maker
Do i need to add water to my slow cooker if so where do put it
All the ingredients in a crock-pot meal go into the ceramic pot. You don't add any water to the cooker itself. The cooker is basically just a holder for the pot and provides the heat. Any liquid goes into the pot with the rest of the goodies. The pot on many models is removable for serving and cleaning, while the base should be kept away from water (like any other electrical appliance).
If you need a manual for your cooker, you can try here for Rival brand models, here for Hamilton-Beach products, and here for West Bend. Chances are you'll find your model or one similar enough that it should clear up any questions.
Now, what's on the menu?
Nov 23, 2010 | Crock Pots & Slow Cookers
My Kenmore HE2plus washer model #110.47532600 keeps giving me the f21 error code. After running it on the drain cycle only I can get it to drain but sometimes it takes two or three tries. Please advise?
F21 error usually means your drain filter is plugged. Typically caused by small items such as hosiery socks and such small things. Remove the bottom panel, you'll see the drain plug right away. Get a shallow pan and place under the drain plug to catch the water that is still in there. Twist the plug off and drain 2-3 cups of water in there and remove all the junk. This is part of normal maintenance that Sears never bothered to tell you about in the manual and you really should clear the drain filter monthly or at least every other month.
Jan 12, 2010 | Kenmore Washing Machines
Where is the drain on the Aruba Majestic Hot tub? I have never drained the tub and would like to keep it empty for a few months before refilling
the drain is located on the very lower left corner of the tub. (lower left is decribed as where the control panel is at the top, look at the bottom to find the plug and insert a hose to keep the water flowing away from the tub.
Oct 10, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Keurig B100 Coffee Maker Logo
123 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
