Question about Graco Quattro Tour - Zurich Stroller
JUST WONDERING WHERE I CAN GET SPARE WHEELS FROM AS MY ONES ON THE BACK ARE GETTING FLAT model number: 7B94VDSY
  • 2,359 Answers
On October 20,2010,Graco issued a nationwide recall on their Quattro and Metrolite strollers.
Check HERE for the exact model on the recall notice.
Posted on Jan 05, 2011
    Problem Solver:
  • 14 Answers
Hiya,
I have looked this up for you. If you call the graco customer service department on this number 0844 412 1212 they will be able to help you.
Good luck.
debs
Posted on Aug 18, 2010
The brushes on my F7206-900 Hoover Steam Vac Dual V wont spin. Are they operated by a belt or by the water moving through the system? How can they be fixed?
All I'm wondering is how to get the back plastic by the wheels off? I can't find any screws! This older model isn't like the ones shown on Internet sites. Seems they simplified the model, which is a good thing.
Aug 29, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I don't have a manual and I'm wondering can I get netflix on this blueray player?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Apr 02, 2011 | Televison & Video
I am wondering where I can find a manual for this product or something to explain how it works? I have a red LED lit on the front and I am wondering if that is normal or if it should be green like the...
I hope this helps.
Mar 28, 2011 | Televison & Video
I need to know how to get the spare tire from under the Uplander. I am second owner and have no manual for my van. Please help me.
Do you have the original jack and related tools I hope? The jack is located in the rear passenger side access panel at the back of your van. The jack and related tools are in a black bag wrapped around the jack and the whole thing is attached to the inside wall. In the bag, you have two tools. One is a wrench with the flip out socket at the end that you use to remove the lug nuts to your wheels. The other tool is a rod. The rod on one end has a hex bolt that fits your lug nut tool and the other end is a flat tip screwdriver. With the rear left gate open, you can look along the top of your bumper surface just under the rubber seal and to left of the gate lock pin by a few inches you will see a hole. This is where the flat tip screwdriver tool is inserted. Insert into the hole and rotate the rod to engage the slotted tip in the hole. With your lug nut wrench, attach it to the hex head end so you can turn it. Turning it counter clockwise while holding into the hole will lower your spare wheel to the ground. You then have to flex the wheel support on the end of the cable sideways to fit through the hub of the wheel to get the spare out. I think this mount is for just the spare and stock hub cap wheels. If you have custom wheels, you will have to carry the flat inside the vehicle to get it to a garage to fix it. To dive off, make sure you turn the crank tool clockwise to recoil your cable so it is not on the ground. The same is true when you Put your spare back. To put it back on, lower the cable, insert the support through the hub of the wheel and ensure it grabs the hub so the wheel does not fall off. Crank the cable clockwise to raise the wheel. It will get hard to turn when the wheel is all the way up. The space saver spare is stored under the vehicle with the air stem pointed down so you can air it up without having to take it off the vehicle. (60PSI)
I hope this is enough detail and that you have all the equipment. Also, Caution, I learned the hard way that the original jack is not very strong. If possible, be on a level surface when using it with no one getting in and out of the vehicle. Mine failed due to being on slight hill with kids getting in and out.
I hope this helps.
Oct 15, 2010 | 2005 Chevrolet Uplander
My dryer vibrates loudly, wondering if it is a bearing problem, and if so, is it worth getting fixed?
vibrations and such noises are definitely caused by something out of balance, or not spinning truly. some maytags were plagued with wimpy blower wheels which when worn made horrendous noises. without a complete model number i am at a loss as to where to point you though.
enjoy, have fun.
Aug 03, 2010 | Dryers
Do i need to replace all four tires if one went flat? what are the limitations of the spare?
You only have to replace the one that went flat, but if the other three are well worn, you may need a full set.
Plus, you generally cannot mix tire tread "on an axle", meaning tread on the front wheels should be the same, tread on rear wheels should be the same, but tread on front and back wheels do not need to be the same.
For the spare, it depends on if it's a full spare, or lightweight spare, meant to get you to a tire repair location. If so, limits are usually written on the tire, which is typically 50 miles and (I think) max speed of 50 MPH.
Dec 13, 2009 | 1998 Subaru Legacy
Emblem Removal
buy the new ones and see how they fit
Jun 15, 2009 | 1986 BMW 3 Series
Back wheels eed replacing
Our back wheels need replaceing to our chicco buggy tuvgs. can you help[
Mar 27, 2009 | Chicco London Stroller Umbrella
Front wheels on quinny buzz are a nighmare....
http://www.babycare.nl/quinny-buzz-all-terrain-front-wheel-p-1819.html?language=en&name=Quinny%20Buzz%20All%20Terrain%20Front%20Wheel
Mar 26, 2009 | Quinny Buzz Three Wheel Stroller
Graco Quattro Tour - Zurich Stroller Logo
91 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
