Question about Irons
I have a Morphy Richards Steam Generator, Model No 42278. After replacing the filter with a new item , the machine will not generate steam anymore. Can anyone help?
3 Suggested Answers
  • 3 Answers
SOURCE: morphy richards steam generator model 42271
is there a noise when u press the trigger? if not there is sometimes a reset button on the front of the base. failing that the problem may well be the solenoid which opens to let the water into the steaming tank which is repairable but can be awkward.
Posted on Feb 06, 2009
heatman101
  • 43501 Answers
SOURCE: morphy richards steam generator iron
Try bottled spring water... many times tap water will not steam right...
heatman101
Posted on Aug 31, 2010
Steam generation minimum morphy richards
If tap water is used in a hard water area limescale can soon build up and reduce water flow into the steam generator.
A propriety descaler might help but if the situation is too advanced it is unlikely.
Mar 03, 2015 | Morphy Richards Irons
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 24, 2012 | Irons
My team generator iron will not steam
Have you any other suggestions? Yes. Dump it.
Jul 16, 2017 | Morphy Richards Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Generator iron gets warm only no steam
PLZ SPECIFY THE BRAND & MODEL NO OF THE PRODUCT TO SPECIFY UR ANSWER
Aug 16, 2011 | Morphy Richards Irons
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
Morphy richards steam generator iron heating up but steam isnt working as it should?
heatman101
Aug 31, 2010 | Irons
Morphy richards steam generator model 42271
Feb 01, 2009 | Irons
Irons Logo
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
