I have a HP dv9000 laptop computer and the dvd drive doesn't work. I tried uninstalling the driver and the drive and reinstalling but doesn't work. The drive does not show up in the cmos or in system devices. I also tried removing the upper and lower filters in the registry but to no avail. Do you have any suggestions? If the drive is defective how could I tell? Thanks, Colin
  • 4,281 Answers
For that you need to remove drive from laptop. You can pull it but before that you have to open it's lock system there. Then you can pull it. Then refix it then if it will working fine then you can see it in bios. If you can see driver of cd rom in device manager then it means that drive is working then only issue with os or registry settings. So if you repair your windows it will work again. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 07, 2010
My Toshiba Satellite laptop computer doesn't play the DVD in the DVD driver nor does it have the D: drive icon in My computer
The DVD drive is not installed or was uninstalled due to faulty driver installed. So you need to open the control panels, open the device manager and check the DVD drive or the drivers.
If this is not seen then reinstall the drivers. If not the hardware has errors and needs to be replaced.
Aug 17, 2011 | Toshiba Computers & Internet
Hp dvd rw ds-8a1p drive driver please
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disk the drivers could be on it
hope this helps dont forget to vote
Mar 12, 2011 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
DVD drive on a HP dv9000 not recongized.
your drivers may have been corrupted or you might have a virus run your antivrus program
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 13, 2011 | HP DVD DRIVE DVD Drive
I have a new HP - Pavilion dv7-3112sa Refurbished Laptop. The Disk drive is not playing DVDs or CD ROMs. It will play audio CDs fine but when I put in a DVD or CD ROM it just buzzes but does nothing.
It sounds like the drive may be bad. You may want to try getting any updates that may be available from the manufacturer. Also if it does not work you could try reinstalling the drive.
To do this go to start > right click on my computer or computer > select properties > click on the hardware tab > then select device manager > within the device manager look for DVD/CD-ROM drives > click the plus symbol on left > double click the cd dvd drive > this will open the dvd properties within here click the Driver tab on the top of screen > then click uninstall button. > Once uninstall ed restart computer. When the computer is loading back up it will reinstall the dvd drivers.
If this does not resolve the issue contact the PC manufacturer.
Oct 21, 2010 | Computers & Internet
My cd/dvd driver is not working on my hp notebook
Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
Jul 24, 2009 | HP Pavilion dv9000z Notebook
Can't read dvd inserted..it says a blank dvd
have you tried reinstalling the dvd drivers?
I would try that and see if it works.
also make sure you set to the proper region for your dvd's
you can only change the region a couple times so go easy.
May 31, 2009 | Computers & Internet
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
HP CD/DVD optical drive is not recognized
I found that there was a firmware conflict caused by the installation of iTUNES. I uninstalled and cleared the upper and lower filters in the registry and the internal DVD-Rom is recognized. First I cleared the registry and the drive was recognized after a hard boot. So Far no twitches. Knock on wood.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
