Question about Nitro BMW-482 Car Audio Amplifier
The light turns on red then turns off completely
When you power off the unit, it goes from bright led to low light led and shows a red light staying illuminated. Which means its STILL drawing battery. How do you turn it off completely?
Brake Hydraulic System Red Warning Light - RepairPal
repairpal.com/brake-hydraulic-system-red-warning-light
If the brake hydraulic system red warning light comes on and stays on, this indicates... and seems to come on and off depending on whether the vehicle is turning, ... if it is discovered that the light was illuminating due to a low brake fluid level.
Sep 10, 2015 | Cars & Trucks
My playstation wont turn on. The red button shows but when I try to turn it on it goes green for about a second the turns yellow for a second then it turns off. At times it will just blink red. What does...
when the lights do this that means that the playstation is broken
on the internet it is called yellow light of death (ylod)
what i recomend you do is call sony even if your warnenty is run out they might replace it for free
fixing it your self is not easy and i do not recomend it
May 08, 2010 | Sony Playstation 3 (PS3) Console
Have no manual. when charging battery re light is
If ithe red light doesn't turn green or turn off, the battery isn't taking a full charge. It needs to be replaced.
Feb 07, 2010 | Canon Cameras
KLH R5100 is not turning on
The light is supposed to work in reverse to the system; i.e. light off= system on; light on= system off...
Dec 21, 2008 | KLH R5100 Receiver
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Oct 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Nitro BMW-482 Car Audio Amplifier Logo
47 people viewed this question
Top Nitro Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Morne Olivier
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
