Question about Acer NSK8458AN Keyboard
Keys either stick, or repeat like crazy. Mostly the keys sticking. Thanks, wahegg@gmail.com
  • 11,896 Answers
You can pull the keyboard apart, upside down. Then remove the rubber piece. Clean the entire piece with rubbing alcohol and a cotton ball. You can also do this to your keys.
Posted on Aug 07, 2010
  • 1 more comment
  • wahegg Aug 07, 2010
    I don't see how to do this when I turn it over.
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    there should be 4-6 screws in the keyboard on the bottom you can remove.
    Sometimes they are placed under the rubber feet.
  • Nate Stansfield
    Otherwise take rubbing alcohol and a cotton swab and clean out each individual key.
    There should be a way to open up the keyboard as you can get replacement pads for the inside.
  • 2,841 Answers
You have a choice. Clean the keyboard you now have or buy a new one. If it is a cheap keyboard I would just buy a new one which you can buy for as little as $10. If it is a nice keyboard you want to keep then a good cleaning will solve your problems. First, shutdown the computer and then disconnect the keyboard. Turn it upside down and using compressed air blow around all the keys. Tap it a few times to dislodge any debris. Now using isopropyl alcohol and cotton swap or Q Tips, clean in between all the keys. Be patient and clean in between them all. Reconnect the keyboard and start the computer. If this does not solve the problem then you will have to give is a through cleaning by removing the keys. Draw a diagram of where the keys go before removing them so you know how to put them back. Remove them all by gently prying them off with a butter knife or screwdriver. Do not remove the space bar, enter, shift, backspace, caps lock, etc. Just remove the small keys and leave the large keys alone as they can be very difficult to put back on. Now clean all the keyboard with compressed air. Blow under each key to remove any debris. Wipe each key down with alcohol and use a Q Tip to clean the underside. Clean the keyboard surface with a lint free cloth dampened with alcohol. This takes patience and time to do it right. After everything is clean then just place the key in place and press until you hear it click home. If the keyboard still has sticky keys, you will need to replace it.
    Thankew! =0)
    Thankew! =0)
What product to lubricate a new ignition switch that is sticking
If it were mine, I would squirt break cleaner or electrical contact cleaner into it to dry it out and let it set to dry completely. I would then squirt powdered graphite lube into it and work the key in and out repeatedly. I would then unhook the battery and switch it on and off repeatedly to spread the graphite around inside the tumbler.
Apr 25, 2014 | Office Equipment & Supplies
When first starting to type the first key sticks and types same letter 7 times.
Open Keyboard in Control Panel
on the speed tab make changes
To adjust the amount of time that elapses before characters repeat when you hold down a key, drag the Repeat delayslider.
o adjust how quickly characters repeat when you hold down a key, drag the Repeat rate slider.
Apr 24, 2013 | Computers & Internet
I cannot install it properly.please send me authorization code to nawazsarfaraj78@gmail.com
1. Install Adobe Photoshop CS2
2. Open the keygen and hit generate key and stick that key in Adobe Photoshop CS2.
3. When it says cannot be activated, click Activate By Phone.
4. Copy the Activation Code from Adobe Photoshop CS2, stick it in the Keygen, and hit Generate Auto Code.
5. Your done
May 28, 2011 | Adobe Photoshop CS2 for PC
Two of my keboard keys got hit by a child. They won't return to playing position. CLP-370
you'll need to open the keboard and check for the keys that has a missing mechanism on it. It usually is a stopper to prevent the keys from "sticking". You can use crazy glue or mighty bond to stick the broken parts together.
Hope this helps
Dec 22, 2010 | Yamaha Full-Size Keyboard
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
My keys sem to stick a lot and when i try to delete it wil only delete one letter at a time
If your keys are sticking, I would suspect a dirty keyboard. I have cleaned them, but it is a time-intensive job. We can provide instructions (mostly taking the keys off and cleaning them and under them and then replacing them).
Also, you should only delete one letter at a time. If you have turned the keyboard repeat off in the CMOS setup, the keys won't repeat.
Sep 14, 2010 | ASUS P5V800-MX Motherboard
Some keys on my keyboard keep sticking
hi Linda - keys stick over time because dust, crumbs, etc. get under them and cause them to stick.
Many times you can just repeatedly hit the sticking key a dozen or so times and restore it to its original status. Actually what u r doing is pulverizing the dust or crumbs into micro pieces..
Also try carefully tipping the open laptop upside down on a piece of newspaper or bed sheet and tapping it as if u were burping a baby.
Try these things and let me know. If I don't hear back cause it is resolved, kindly score my answer as a fix ya! thanks.
Feb 27, 2009 | Toshiba Tecra A8-S8314 Notebook
When I hit the Period Buttom it repeats the ..... multiple times ....
you seem to have a stuck key try popping off the individual key pad and check for anything that will cause sticking
IE dust, foreign object, moisture, corrosion.
Jul 24, 2008 | Logitech Cordless Desktop MX3200 Laser...
Echo,beep,stick repeat
Do you both use DSL/CABLE internet?
What IM client do you both use?
Nov 11, 2007 | Labtec Webcam Pro
Acer NSK8458AN Keyboard Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
