Question about LG Refrigerators
Icemaker will not work. water will not fill the icemaker
  • LG Master
  • 3,051 Answers
Hello there:
If there There's no ice Please read this entirly to assist you in troubleshooting this problem. If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Aug 07, 2010
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
How to Fix whirlpool icemaker
water not filling icemaker faulty you may need technican.
Jun 22, 2014 | Whirlpool Refrigerator Icemaker Ice Maker...
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Sep 12, 2009 | Refrigerators
Ice tray dont empty and water keeps running out
Something caught inside the water valve (replace water valve ) such as dirt , sand . Or , the icemaker died in the fill position . Disconnect the icemaker plug inside the freezer , and see if water still runs from the icemaker fill tube . Also make sure the icemaker fill cup on the icemaker , is not clogged with ice .
Sep 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I am getting no water to go into my ice maker , eveything else works fine , just no water???
Check fill tube that goes to the icemaker in the back. It may be filled will ice or the water valve may not be sending water to the icemaker. S xS have a dual valve, one goes to the icemaker, the other to the door. This is why one may work but the other doesnt. Replace the water valve on the back of the icemaker.
May 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
585 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
