Question about HP Digital Projector sb21 Multimedia Projector
Why is the projector looking for a signal? - HP Digital Projector sb21 Multimedia Projector
  • 89 Answers
Need input signal from Computer or DVD player. You will have to select RGB or Video in the projector menu.
Posted on Aug 10, 2010
Projector Purple Ghosting
aperently it has to do with converting the analogue signal to digital or the other way around..rca is the cable type..the signal is what you are having issues with..you may need a converter..it may also require going into the setup menu of the tv and make it recognize the signal..
Feb 08, 2014 | Office Equipment & Supplies
Will not regonize computer source
The projector looks for Horizontal sync & Vertical sync signals from the VGA source. If it finds these signals only then the source is connected. Even if the sync signals are found, the RGB switching should be working. Either there is a problem in sync circuitry or RGB switching. You need to be well conversant with the circuitry.
sonsunny
Mar 29, 2011 | InFocus LP120 / 1000 Lumens / XGA / DLP...
No signal
are you sending the signal to the projector. FN+CRT/LCD button key simultaneously. if you do this 3x you will get the following. no image at projector image at laptop scree, image at projector and laptop screen, image at projector no image at laptop scree,
Jun 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
Why does my projection look green if the colors are right on the computer?
I'm going to guess that you are using an RGB cable to connect to the projector and the projector is expecting a composite signal. The composite signal would be what uses a yellow connector when you use hte red/whjite/yellow type of cable. All of the video is carried by the yellow. If the projector is expecting this and you send out component (RBG in this case), then the only video signal processed is the green. Since the green also contains the sync signal, the picture will be seen but green.
Check the menus on the projector. You should find a video selection area that will allow you to change to component input.
Please update this if you have any more questions.
Dan
Feb 03, 2010 | Dell 2400MP DLP Projector
I have a dataprojector, no signal
Then 'No signal' or 'unsupported signal' messages are usually because your display is set too high. To see if this is your issue, hoop it back up too your computer & set the computer to the basic VGA resolution. Assuming you are using windows, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes, then drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector.
Note for Laptop users-- By default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue <fn> button (on the lower left of the keyboard, usually to the left of control <crtl>) and tap the bleu button you just found. Let go & give you
Nov 14, 2009 | Toshiba TDP-S81U DLP Projector with...
No Signal
On your notebook press fn key and look for F# key that has a monitor or lcd picture on it( ex: F5 or F4). and press on it as well while holding down fn on keyboard
Apr 08, 2008 | Optoma EzPro 739 Multimedia Projector
No input signal form a laptop to a projector
Hi jkoceng,
What type of interface cable are you using to connect to the projector? 15-pin VGA? S-video?
Generally on laptops if you look at the keyboard on the function keys (F1, F2, etc.) you'll see little icons such as adjustment of volume, brightness, etc. Look for one that looks like a monitor or screen. Usually this is on the F5 or F6 key. If the icon is blue, look for the corresponding key on the keyboard (Fn key, CTRL, Alt, etc.) and then hold that when connected to the projector while you press the appropriate function key. This should alleviate your problem.
Of course, you'll also want to be certain that you're using the correct input function on the projector.
Ben
Mar 13, 2008 | Computers & Internet
No image
1-SWITCH YOUR PROJECTOR OFF.
2-CONNECT EVERYTHING AS NORMAL CONNECTION.
3-SWITCH DOCUCAMERA ON.
4-SWITCH YOUR PROJECTOR ON.
5-CONFIRM THAT INPUT OF PROJECTOR IN RIGHT INPUT TO CAMERA.
6- CONFIRM THAT CAMERA CABLE IS GOOD BY PLUGING IT IN VIDEO INPUT OF ANY TV.
Mar 06, 2008 | Epson - PowerLite S1+ Multimedia Projector
No signal for my lcd projector
You have to "Toggle" your PC to output the signal to the projector.
On which "F" key do you see "CRT/LCD" or a pictute that looks like a monitor?
Steve
Jan 08, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
HP Digital Projector sb21 Multimedia Projector Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
