Question about Stanley Utility Knife
How do i change the blade in a stanley fatmax?
    New Friend:
You do not have to remove any screws. Extend the blade outward using the thumb slide on top of the knife. There is a small black pushbutton on the opposite side from the lock button. Depress the button on the side and using the other hand, grab the blade with your thumb and forefinger to pull the blade out. It may require a little wiggling. Now the new blade can be slide in and locked into place. The black pushbutton controls the locking mechanism that keeps the blade from pulling out.
Posted on Jan 14, 2013
  • 10,319 Answers
Remove the housing screws to open
Posted on Aug 07, 2010
  • snap_knight Mar 16, 2011
    From the sound of it, you don't even own one.
  • muffoletto Apr 19, 2011
    I agree! Have you ever actually seen one of these things. Even after removing the screw (there is only one) it still will not open. Were these things made in China?
3 Suggested Answers
  • 436 Answers
SOURCE: Loading instruction to change blade on Stanley
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part.
Now slide the yellow part back to reviel the blade folder.
Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Posted on May 03, 2011
puertobori
  • 7733 Answers
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
Posted on Nov 08, 2010
Change blade stanley fatmax knife
Watch this video.
https://www.youtube.com/watch?v=do8W9t3gRp4
Mar 09, 2018 | Stanley Measuring Tools & Sensors
How do I remove the original packaging from the fatmax
I agree. The packaging is ridiculous.
I removed it by grasping the packaging and pulling (very hard) from the blade end (bottom left as looking at it) straight out. This stretched and tore the plastic "paper" and pull the knife free.
Feb 01, 2014 | Stanley 10-778 FatMax Retractable Utility...
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
Jul 13, 2011 | Stanley Fatmax Xtreme Retractable Utility...
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Mar 06, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
Stanley  Utility Knife  Logo
1,734 people viewed this question
Top Stanley Cutter Tools Experts
Ivan
Ivan
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Pete Jones
Level 1 Expert
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
