Question about Hampton Bay 24002 Ceiling Fan
Fan direction will not change with remote - Hampton Bay 24002 Ceiling Fan
  • 10,319 Answers
Switch it manual on the base of the fan housing. If that works get a new remote
Posted on Aug 07, 2010
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
How do you reverse the fan to move the oppisite direction for summer. Our fan is controlled by a remote.
My parents had a cassablanca fan that utilized a three button remote and if I am not mistaken to reverse the direction you held down two of the buttons at the same time for approx 3 seconds and the fan would make a different beeping sound than it does normally when changing fan speeds and bingo it changes direction. It should work, all fans work basically the same . Good Luck
Jun 27, 2010 | Hampton Bay 23509 Fulton Ceiling Fan
How do you change direction? I cant find the switch. Remote?
Hi ,
The slide switch should be just above the light fifixture and below the fan blades. Good Luck !!!!!!!!
Jun 19, 2010 | Hampton Bay 52 In. 5-Blade Fan, Iron...
HAVE AN EMERSON FAN WITH REMOTE ONLY THAT I CANNOT CHANGE DIRECTI
First, tell us the model of the fan as well as the receiver and remote?
Can not solve a answer without a thorough question...But I am willing to help.
Apr 08, 2010 | Emerson Fans Emerson SW375 Receiver
Minka Air Concpet II Fan with wireless remote will not switch direction. Currently only turning counter clockwise. Wil stop and start and the light will turn on and off but it will not reverse
what you actually need to do is have the fan on ie. spinning (albeit in the wrong direction) then press and hold the change direction button. after about 10 seconds or so the fan will slow down and then start to spin in the opposite direction.
it's silly they don't make this clear in any of the instruction manuals.
Feb 16, 2010 | Minka -Aire Brushed Nickel Remote Control...
The remote control works other than changing the direction of the blade. how do i manually change blade direction?
Look on the side of the Fan above the light fixture there is a little black switch you just need to switch it, make sure the fan is off before switching it.
Jan 11, 2010 | Hunter 52" Ceiling Fan With Light And...
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Hampton Bay 24002 Ceiling Fan Logo
131 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
