Question about Sony Playstation 3 (PS3) Console
My playstation 3 refuses to start up. When turned on it reaches the main menu but freezes up. Then the system flashes a yellow light and shuts down to a red light. I want to get my ps3 up and running again.
    President:
  • 1,197 Answers
2 days ago i got the yellow light of death when the 2.50 update came out rendering my ps3 to a 500 dollar paperweight.
I contacted sony about my problem and my console is under warrenty so it would be fixed for free so it didn't bother me to awful bad
the are sending me a box right now but i have fixed the yellow lights on my ps3 myself and it works now without a hitch
What i did is i took my 120 gb hard drive out of my ps3, Saved it to my cpu tower and did a full format of that drive
then i took my hard drive and put it back in my ps3 and it ask me for the system software 2.50 disk so i downloaded the 2.50 update off of the ps3 website installed it and boom my ps3 work like new
this worked for me so far and have been playing my console for 6 hours now with out a hitch
maybe this will work for some of u aswell
Posted on Oct 09, 2010
Playstation 3 shuts down and cant reset
Does it blink red or yellow lights? That's a sign of hardware failure and the system needs to be serviced.
May 14, 2014 | Sony Playstation 3 - System - 500gb -...
I turn on the playstation 3 and it turn the green power light on and the back fan starts to run but then it shut down and the red power down light flashes
Hi porterfastca,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Mar 16, 2011 | Sony PlayStation® 3 (60 GB) Console
The PS3 works fine but freezes in career mode of MLB 10 The Show. Is this also an over heating issue?
It doesn't sound like an overheating issue, more of either a disc read issue or firmware issue.
Please try my following tip for re-installing the firmware. If this does not fix it then try cleaning the laser lens.
Failing that, if it is an overheating problem usually it will tell you with an onscreen prompt or shut down with a flashing yellow light
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says
Hopefully this will cure the problem on its own.
Hope this helps
Jan 29, 2011 | Sony Playstation 3 (PS3) Console
When i turn my playstation on, after 5-10 seconds it shuts off by itself and the red light keeps flashing, what do i do?
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
The PS3 red light problem occurs when your system refuses to boot up and has a small flashing red light on the power button. In most cases, the power button will turn from red to yellow and then back to a blinking red and the system will not boot up from there as it is supposed to.
There can be a variety of issues that cause the Playstation 3 red light problem, but in most cases it comes down to the system overheating. The more it overheats the more damage is created internally to the motherboard
and other functioning components. This can be caused simply by a flaw in the system or by obstructions to the fan vent such as a wall, floor, or excessive collection of dust...
click here to download repair guide
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
My Playstation 3 often freezes up after a short period of use. After that, it refuses to turn back on again, and its light flashes back to red from green whenever I attempt to turn it on. Either that...
did you try to force the pS3 reset mode? press the power button for 08 seconds and wait the system restart...release and wait it reboot...if the problem persists...try to change and install a new sata hdd and restore the ps3 system...see if your ps3 hdd is really ok...test it...Or could be the Ps3 Motherboard hardware problem...called YLOD...does your Ps3 light flashes yellow??
Good Luck!!!
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 will not work - powers itself down
Hardware Failure. You can try using some of idea from this guide:
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=3290911
MAJORITY of the time it's a GPU problem though that only Sony or very experienced techs can fix.
You can reach SONY @ 1-800-345-SONY
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezes before getting to main menu!!
I had the same problem bud. I rushed and contacted sony but the next day my friend told me a great solution tht safed me 150 $. Well basicly your ps3 is lika a PC. All you nerd to do is to get to the hard drive menu. By holding the power button for 10 sec but do that for 3 times. That will take you to the blue menu. From there just reset your hard drive and wola brand new.
Ps Same thing happend after i downloaded the house app. booo to the house lol
Jan 20, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Hold the power button down; the system will turn on and turn off once again
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
When you hear the 2 beeps take finger off power button
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
