Question about Citizen IDP-3210 Printer
Will not print , error message on monitor says printer index out of range. This printer, IDP 3210, stopped working when a a second printer- a lexmark-was replaced with a HP printer. The IDP-3210 is not the default printer. We tried reloading drivers downloaded,from Citizen website to CD and compatible with the Windows XP. No change in performance. Still says printer index out of range. IDP printer connected to computer with serial cable. The computer to which the IDP is connected is stand alone and not accessible to the internet.
4 Suggested Answers
SOURCE: Citizen iDp 3550 prints double-spaced
It is a dip switch setting, on dip switch #6, it needs to be "On" It will then single space the lines. After re-setting the switch under the cover, turn off the printer for 30 seconds to clear the buffer...then holding the "LF" button, turn it back on, until its self test is complete. You problem will be over.
Posted on Feb 06, 2008
marked
  • 6487 Answers
SOURCE: I need the owner manual for Citizen idp 3535 printer
You can download the user manual from this link for this device
http://www.citizen-systems.co.jp/english/support/download/printer/document/user/data_box/iDP3535UME.pdf
Posted on Jan 29, 2009
gvctts
  • 103 Answers
SOURCE: I need vista driver for citizen idp 3541 priner
Dear User, here is your requested driver. Please click link below and download will start automatically.
Note:- please dont forget to RATE my solutions.
http://www.citizen-europe.com/files/367b-9xnt2000xp.zip
Posted on Sep 07, 2009
My HP Photosmart All-in-one 3210 will not print. The last error message says service product. Earlier I got error message oxc 18a0401 and Ink System Failure. It will not copy or print. It will scan. Is...
You can reset it by unplugging it an leaving it unplugged overnight. Then, plug it in and restart it. This may sound crazy, but could you be out of ink, or the ink cartridge may be bad. Would need more info to advise properly, such as; what were you doing when the error happened, what was the last thing you did directly before this as far as printing goes, and could a file in your program been corrupted:? Please try the simple things, then let us know, ok? Good Luk!
Jan 05, 2011 | HP Photosmart 3210 Printer
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Oct 07, 2009 | HP Photosmart 3210 Printer
Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Jul 20, 2009 | HP Photosmart 3210 Printer
Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 05, 2009 | HP Photosmart 3210 Printer
I have a HP photosmart 3210 All in one. It is showing an error message; ink system failure. Ink system has failed unable to copy, receive faxes, or print. Refer to printer documentation. Error 0xc18a0401
Hi ok try this I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 21, 2008 | HP Photosmart 3210 Printer
My 3210 will not scan
I now have 2 of these and both print ok but can not scan with either, never tried to till now.
I have re- downloaded the driver from HP.com via Internet Explorer (usually use Mozilla Firefox) and i get 2 diff. error messages : network busy (impossible since it is connected via USB) and the 1 at my office connects wirelessly but error message is something to do with software.
Thanks!
Nov 02, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210
Try reinstalling your display drivers. you'll be surprised how dependent printers are on display drivers. Try changing the font as well.
Do you get any error messages once you click the print button? is it sending to the correct printer?
Jun 15, 2008 | HP Photosmart 3210 Printer
Carriage jam
firstly open door of printer
and clean any soft cloth then start printig .if not solve problem then check belt of carriege motor and screww
Oct 26, 2007 | HP Photosmart 3210 Printer
Citizen IDP-3210 Printer Logo
977 people viewed this question
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
