When trying to perform Z function, an error message 'turn key' comes up on the display and the alarm sounds and cannot be cancelled. Reg functions work as normal. Machine is a Casio TK 2700 Urgent please
  • 17,970 Answers
You have turned the key before finishing in the mode that you were in.
e.g. you may be half way through a sale in reg mode, but forgot to finish the sale before turning the key.
Turn the key to reg mode and press CASH. If you have an RF mode, try turning to there and pressing CASH. If the drawer opens, then you should be ok. Otherwise, you may be in the middle of programming. turn to program mode, and press SUBTOTAL. If you find the message goes away when you turn to a certain mode (except for off mode), then that is probably the one you were last in, and need to finish in.
Tell us news.
Posted on Aug 07, 2010
Bizhub600 error code c3502 it come several time
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier. 21363730 Bizhub 600 konica minolta This link has some more info as well
Oct 03, 2015 | Office Equipment & Supplies
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
May 22, 2014 | Electrolux Dryers
TEC MA-1650 Cash Register It appears the register has been put into a sub programming mode somehow and we are unable to get register functional again. When Register is switched to Set there is a P...
Perform a status clear.
turn key to blind(must be S key not mgr key) while holding zero key down turn reg on with power switch on right side.
reg will beep once & print reciept saying status clear.
this wil not clear programs or totals.
Dec 12, 2010 | Office Equipment & Supplies
Err68
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Canon MP390 - "Data Error Press Set Key" Message
No free suggestions go to the authorised service centre or trying to get an live chat support from canon like I do from my hp printers
Feb 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off.
STEP3.press 14 then press print button
Jan 29, 2009 | Sharp AL 800 Copier
I am unable to print anything. First the printer makes an awful noise and it takes an awful time to trying to start printing, but nothing happens and the cancel light comes on. It also mentions...
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release in sequence the "1", "2" and "3" buttons.
Customer Name: ok
Customer Name: screen says "support" R0631M
2. Press and release the right arrow button until the display says "System Configuration Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photo Smart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
HP: Is the error message still being displayed on the printer?
May 02, 2008 | HP Office Equipment & Supplies
k24674
jasbo
jasbo
Marvin
Marvin
