Question about Hayward Gas Swimming Pool Heater 100k Btu Natural Gas
The heater is working but it is making a loud crackling sound, almost like small rocks inside it. I haven't used it in a few months. What do you think it could be? I have the model either H1001D1 or DP1.
    New Friend:
Water flow is low - filter is plugged water is turning into gas and exploding
Posted on Jun 28, 2017
3 Suggested Answers
  • 990 Answers
SOURCE: i have ahayward H1001D1
If your external by-pass is closed almost all the way then it will be your internal by-pass. You find this assembly inside the water manifold at the side of the heater. Part should be about 70-80 bucks.
It is suppose to regulate the water flow so it has time to heat but not boil. Yours is probally missing the control disc and letting all the water flow past the heater so the water in the heater is boiling and that is the banging you hear. Good luck.
Posted on Sep 04, 2010
  • 10865 Answers
SOURCE: My Hayward pool heater Model
hello cpr... you have air trapped in your heater. turn the pump off for one minute and then on for one minute and repeat until the trapped air is dissipated. Joe
Posted on May 31, 2011
Have a 1 year old Delonghi oil heater and has starting to make loud crackling noises when hearing up for about 5 mins.
The sound you are hearing is the metal and the oil inside expanding. When you heat metals they expand. When it cools it shrinks. I would imagine that when you turn this off it is also making these noises but you are not there to hear them like you are when you turn it on.
Sep 23, 2014 | DeLonghi Heating & Cooling
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
I have a yaesu ft-736r with no audio
Hi Jermaine,
It transmits, but no receive, are you sure, have you tried playing around with the volume control?
If, so did that make any crackling noise? If so, then this is due to lack of use of the volume control, many radios, including the old transistors with dials, would make crackling sounds when you adjusted the volume, and as I say, this is due to lack of use, So if this is the case and to get your receiving, turn the volume control up & down fully for a few minutes and while doing so your radio might receive a transmission that will be loud, quiet, loud, quiet, etc., as you play with the knob.
Keep doing so until all crackling has disapeared.
Do this often as possible when firing up your radio for the day, the more use these controls get, the better.
I hope this has answered your query.
Cheers,
Peter
May 29, 2012 | Yaesu FT-736R
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
My Lakewood oil-filled electric radiator makes some crackling noises when first heating - is this normal?
Yes, it is normal. the sound is from the oil heating up and moving through the fins. It will stop after a few minute. After the heater is used for a few months the noise will stop altogether. j
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Feb 22, 2011 | Lakewood Oil-Filled Electric Radiator...
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
IBM 21" frequent tick sound!
too much refresh rate! set it to 60 hz only! you're over-stressing major components on your monitor!
Dec 02, 2007 | IBM P 202 21" CRT Monitor
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Hayward Gas Swimming Pool Heater 100k Btu Natural Gas Logo
217 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
