Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Whirlpool Duet Model GEW9200LW1 Dryer I have this dryer that is not working. The lights on the panel do not light up. Verified power and breaker, light in the dryer comes on when door is opened. I could not find any service manuals online. I am somewhat capable of doing repairs myself and am looking for advice as to what the problem is, how to fix it, possibly parts that need to be changed, or whatever advice you can provide.
    Brigadier General:
  • 3,513 Answers
Please find the link bellow where you can download the manual from the right hand side in the pdf format.
http://safemanuals.com/user-guide-instructions-owner-manual/WHIRLPOOL/DUET%20ELECTRIC%20DRYER-_E
Thank You
Posted on Aug 07, 2010
Whirlpool duet dryer GEW9200LW1 heats
If the element was replaced, and now verified that it is not presently shorted to ground, your next diagnostic would be to to test the timer connections per the schematic lookiong for a fused contact that energizes the heater, while set to air fluff setting.
Apr 08, 2014 | Whirlpool Dryers
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Whirlpool Dryers
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer GEW9200LW1
Hi.
To be sure the element is not faulty, you need to have it tested for continuity, and for an earth fault.
Nov 23, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Dryer will not start
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Washing Machines Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
