Question about Whirlpool Duet GHW9150P Front Load Washer
Slow steady leak fills machine then overflows
When the machine is stopped a small but steady trickle fills the washer until it overflows. I suspect a valve doesn't fully close. I am tech-able but would rather not tear into a 2 year old machine without a manual or at least a schematic. does anyone have one they can email or post? Even better know where the problem comes from?
ofrog21@cfl.rr.com
Any help would be appreciated
    Genius:
  • 1,028 Answers
Three screws along back of machine top remove valve wires and screws remove inside hose and fill hoses..probbly have sand or rust in valve..be sure screens are in port and are reinstalled if ever removed to clean
Posted on Apr 27, 2008
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 30, 2011 | Washing Machines
My washer seems is filling very slowly, and doesn't empty all the water out of the tub. I tried both temperature settings and it doesn't seem to matter. It will fluctuate back and forth on how fast it...
regarding your filling problem , most washers have small screen filters at the water intake, take your hot and cold hoses of of your machine and observe the fittings on the machine you will likely find the filters there they are just a mesh screen, remove them and clean , then reassemble this should solve your slow filling problem
May 08, 2010 | GE WPRB8050D Top Load Washer
Water trickles out when filling instead of the steady stream
Check the water inlet valve. Remove the water supply hoses and check the small metal screens inside the valve (especially the hot water side) and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. Here is a photo for reference. Hope this helped and best wishes.
Sep 30, 2009 | Kenmore 23822 Top Load Washer
Our washer overflowed last night. no warranty on
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit. This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port.First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.i f however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, Plug the washer back in (being aware that components in the console are now ‘hot’ and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged..
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. while it is the least common cause of overflow, it does happen and is easily overlooked. sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
Sep 30, 2009 | Kenmore Washing Machines
Front loading washer
if washer is turned off doeas water still come in? if so suspect fill valve if not suspect small hose from tank on left rear corner either plugged or crimped almost closed if hose cks ok suspect water level control
Sep 24, 2008 | Frigidaire Washing Machines
Fill switch cutoff
remove the 2 screws on rear of console pull console slightly forward and roll it up and back..ck small hose to water level switch to be sure it is on..is water stopping when control knob is pushed in?? if not suspect inlet valve replace it ..if it does suspect water level switch or that hose also hose may have small hole in it somewhere or be pinched
Aug 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
