Question about Dacor ECS230 Epicure Electric Double Oven
We clean are double wall oven and I can,t reset the clock.
  • 1 more comment
  • williamk77 Apr 27, 2008
    It flashes but you are unable to reset it when you push the approiate buttons.
    I've taken the cover off the control panel, does't look to diffecult.
    All the other buttons on the control panel work, timer 1,timer 2,cancel secure, bake, all work except for the clock, nothing happens when you push it.
    Brigadier General:
  • 6,966 Answers
Hi williamk77,
Your post "reset the clock" may refer to three (3) clocks in your Dacor ECS230. The first is the "Setting the Time of Day" which could be performed by pressing on the "CLOCK" touchpad. The time of day will falsh. "AM" or "PM" will be displayed and "TIME" will flash in the display. Thereafter, press the touchpad "+" or "-" until the correct time of the day is displayed and release touchpad.
The second is the "Using the Minute Timer" which is better explained at the user's manual page 6. Below is a snapshot of that part of that page.We clean are double wall - 09d8cbe.jpg
and the third is "Timed/Delayed Timed Cooking" likewise better explained at the user's manual (p.9). Should the manual be not readily available, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 27, 2008
  • Louie  Role
    Louie Role Apr 27, 2008
    Ooops, sorry gentlemen for doubling up. again failed to refresh before posting. my compliments to all.
  • 2,326 Answers
Press “CLOCK” touch pad, then press
“TIME•TEMP” pad to set correct time of
day.
    Genius:
  • 3,587 Answers
Go to the circuit panel that controls the oven(probably in the garage) and cycle the power breaker for the oven. Then, when you arrive back in kitchen, it should be flashing...reset it from there..sometimes during cleaning cycle, the digital electronics can glitch.
thankya for using fixya
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Apr 27, 2008
    ahh..ok..then you have a dead panel device behind the access. Do you feel inclined to do this work yourself? You'll need a replacement touch panel, and service manual to open this unit up.
  • Patrick Michaels
    good..now all you need to find is a source for that component. suggest you look on the item, and see if you can detect a part number and maker, perhaps.
  • Patrick Michaels
    well..then you have an done clock button...seems that it will be a timeless appliance now..that can happen in those multifunctional digital panels..one thing drops..gotta replace the whole thing.
  • 3,037 Answers
If you unplug it or trip the circuit breaker you should be able to reset the oven and then be able to reset the clock.
I'm not quite sure if you are asking what button you need to press or whether the button is not working, if the above information does not help, please let me know and give me anything else about this problem that you can and I would be glad to help.
thanks and have a good day
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 27, 2008
    yeah, so just try resetting it first by unplugging it or by tripping the circuit breaker and if that doesn't help, let me know
  • Benjamin Patri
    have you checked the connection of the clock button and wires that it is attached to. It may just be internally broken. Check for a loose solder to. Let me know if you find anything
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
SOURCE: I would like to set the clock.
Hi, You need to turn the large knob counterclockwise and then you should be able to set it , when it is set tot the correct time then you will press select button.
Posted on Jun 20, 2008
Krazytech
  • 725 Answers
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
Posted on Sep 28, 2008
SOURCE: Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Posted on Oct 04, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
SOURCE: clock on cooker flashing
Excellent! Now my clock works, but where can I get an instruction booklet for this oven? Thanks.
Posted on Jun 10, 2009
Used the self cleaning option and now top oven will not heat?
Good Morning Friend,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
Why when i used the self cleaning option on my upper oven will it not heat anymore?
Good Morning James,
-Best Regards-
WP
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
I try to turn on and when I do the temp starts going backwards until it is off. The clock will do the same things after I try resetting the breaker.
is there a time bake or something similar on it,sounds like it's stuck on that cycle,next time send the model number,could have a bad touch pad or clock assy. stuck on a time cycle so no matter what you do it's counting down
Nov 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
Kenmore double wall oven keeps beeping
I have a whirlpool stove and when I try to clean it after awhile it starts beeping and comes accross with E1 & F5 the oven when its to clean dosen't seem like its locking. How can I fix this problem. Ive missplaced my book somewhere and can't seem to find it. My timer and clock is digital. Can you help me solve this problem? Thanks!
Aug 22, 2009 | Kenmore Ovens
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
FGB24L2ABB Frigidaire wall oven
local outlety to buy rack for oven
jeff
May 20, 2008 | Frigidaire 27 in. Electric Double...
Dacor ECS230 Epicure Electric Double Oven Logo
316 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
