Question about Bose (321GS) System
I tried to play a yesdvd but it hung up on the first screen and evidently locked the dvd eject mechanism. How ca I retrieve the dvd? Spencer
  • 11,896 Answers
You can either use a paperclip and stick it in the middle of the tray door, then pull it open, remove dvd, pull tray back slowly as far as it will go, then press eject and see if it realigns itself back on track.
Otherwise, remove the cover and pull the dvd out that way.
Posted on Aug 07, 2010
  • 2 more comments
  • spike99224 Aug 07, 2010
    I cant get a paperclip to go in. Cant pull out the tray by hand. Don't see how to remove the cover.
    My Bose unit is about 7 years old.
    sm
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    if you can not get a paperclip to fit in the center, then try a fingernail file or butter knife.
    In order to remove the cover, you would have to remove all outside screws.
    I can get a knife to go under the tray about an inch, but I can't pull the tray out or move it forward at all. I tried prying the tray out with a small screwdriver, but it didn't budge and I am afraid I will break the casing.
    I see no screws on the top or sides of the unit..
    I haven't yet removed all of the attached cables in the back so can't turn the unit over to see the bottom. Is that where the screws are?
  • Nate Stansfield
    Screws would be either on the back, side or bottom
    When prying the tray open, you can go from top middle of tray and add a little force. It should not brake, if anything just the front little cover may come off which can be glued on. Most are just one piece and are very hard to break.
Locked Tray DVP-SR320 Sony DVD Player
see this causes and fix it. God bless you
Possible causes:
  1. Worn, stretched, oily, flabby, belt.
  2. Dirty mechanism or gummed up lubrication.
  3. Stripped gear or other mechanical damage.
  4. Defective motor or bad connections to motor.
  5. Bad drawer/eject button.
  6. Missing/bad voltages from power supply.
  7. Defective microcontroller or other logic.
  8. Dealer antitheft lock enabled.
Oct 15, 2012 | Televison & Video
DVD tray will not open. Lock is not on. I have tried unplugging the unit then plugging it in again. What do you suggest?
I think your DVD player is trying to read the disk, but it can't. Try unplugging the unit. Holding down the eject button and plugging it back in. After it begins to to power up you can release the eject button. What your wanting to do is to get it to eject before it tries to read the disk. Good luck.
Apr 20, 2010 | GoVideo DVD Recorder/VCR with YesDVD
Dvd/Vcr combo
often if you turn off machine, then hold eject as you turn machine on tape will come out.
Feb 13, 2008 | Sanyo DVW-7200 DVD/VCR
Hung up - disk won't eject
cd recorder disk will not eject
Dec 08, 2007 | Panasonic VDR-M70 DVD Camcorder
Creating YesDVD on GoVideo VR2940
i have found if there is a tracking problem with a tape in a section it will confuse or "lock up" the unit - unplug from the wall for 10sec and retry.
Nov 14, 2007 | GoVideo Go Video DVD/VCR Combo
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
DVD went in...and won't come out
Whatever you do, DON'T try ejecting it manually. it can ruin the dvd mechanism. The problem is in the dvd power supply. If you have some soldering skills and are good with a soldering iron(temperature controlled is best) you can resolder all the three-legged regulators on the dvd power supply board(small board to the right front of chassis). Good success, Meder's Tv
Feb 20, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Bose (321GS) System Logo
24 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
