Question about Intermatic & Malibu& 300 Watt Power/Pack Timer
Should all the red pins be pulled up for the lights to be on for that time
Following link has power pack information.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
The trippers are pushed all the way down.
Red tripper pushes a tiny switch that turns lights ON.
Later when dial rotates around, the black tripper pushes the switch other direction, and lights go OFF.
Trippers can wear down and need to be replaced.
There are no repair parts for power packs, but link above can save you money by helping power pack last longer.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 13, 2011
Does anyone know how to turn off an intermatic E1010? We moved into our new home and have noooo idea how to turn off this thing. We wanna turn off the outside lights . Please help!
You should be able to turn the dial till lights go out, then pull the red and black "pins" from the dial. It works like a clock, one pin is set at the time to go on, the other at the time to go off. By turning the dial forward till the light goes off, then pulling both pins after they go out, they won't go back on till you install the pins back in at the times of your choice.
May 28, 2018 | Intermatic Hardware & Accessories
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
Battery drain on 1995 buick lesabre, where do you start to find it
Disconnect the red battery cable.Take a test light and hook 1end to the + batt post and the other end to the +batt cable. This will make the test light illuminate. Pull 1 fuse at a time until the light turns off. This will pin point the electrical circuit that has "parasitic draw". (be sure to reinstall each fuse that has no change)
Dec 26, 2012 | 1995 Buick LeSabre
I cannot set my GE timer--15119----I have no instructions and have tried many times---I can't believe how difficult this timer is to set----
Here's what I found.
Pull up all of the little pins around the dial.
Push down all pins for the time that you want the light to stay on.
Leave pins up for all time that you want the light to stay off.
Rotate the dial to the current time of day.
Plug timer into wall.
Plug light into timer.
Ensure light is ON.
Gary
Feb 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do you set the timer
You posted under mechanical outdoor timer with time dial located on face.
If you have different timer, add a comment.
Instructions:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There are segments or pins located around outer edge of dial.
If timer has segments.
Pull these segments outward, or leave them in place to set on-off times.
Pull out a few segments and then rotate dial clockwise to see if lights turn on or off with segments out.
Then pull out segments for the times you want timer to turn on-off.
If timer has pins.
Click pins outward, or leave them in place to set on-off times.
Click out a few pins and then rotate dial clockwise to see if lights turn on or off with pins out.
Then pull out pins for the times you want timer to turn on-off.
Some timers also have an override button located on inner dial or somewhere on body of timer.
Move this switch to TIMER or AUTO, depending on your timer
Dec 05, 2010 | Stanley 38445 TimeIt 24Hour Daily Outdoor...
Can't figure out how to set Intermatic timer 111c up to nightlight
Hello. I can help you with this times.
Step one - insert the pins at the times you want the night light to come on and go off. The green pins will turn on the night light and the red pins will turn it off. If you just want one on time and one off time just use one pin of each color.
After you have the pins inserted, set the correct time on the timer and plug it into an outlet that is always on [not one that is controlled by a wall switch].
The override switch will turn the device off if it is on, but just one time. As the next time it turns on it will once again be controlled by the times.
If ou want the night light to come on and off in the evening and again in the morninng, use two green pins and two red pins. Push in a green pin at each time where you want the night light to come on and push in a red pin at each time you want it to go off.
Get back if you need additional clarification.
Jun 02, 2009 | Intermatic & Lighted Dial Timer
Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Nov 30, 2008 | PC Chips M848ALU Motherboard
Connector pulled off power buton wires
Hi ford, the most common case colored wires used for negative - is white. The colors blue, red, green are usually positive +. The internal speaker though it uses a 4 pin connector only plugs onto the 2 end pins. Black is connected to negative - pin & red is connected to + positive pin. (Depending on the MB model).
All these case LED's use 5volts DC. If you make a boo-boo, don't freak out. You can usually shut down the system & turn the connector 180 & re-connect it with out hurting the board. Suggest you connect 1 at a time & check in-between each.
Still having trouble, include the name & model number of the MB.
Mike
Sep 28, 2008 | Computers & Internet
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Intermatic & Malibu& 300 Watt Power/Pack Timer  Logo
49 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
