Question about Acer TravelMate 4150LCi Notebook
Bubble-like spots on lcd
I recently noticed that I have two adjacent spots on the lcd of my acer travelmate 4152. on light colors they appear slightly lighter, and when I shake the screen back and forth they wobble in a way that makes them look 3D, like bubbles. Otherwise just two rounds spots of discoloration.
Any idea what I'm looking at?
thanks
  • yoav kleinfeld Apr 27, 2008
    no warranty and its not something that warrants a replacement. I don't think "dead spot" applies, its more like distorted.
    is this something that gets worse?
  • 558 Answers
Air intrusion do to failed polymer layering new screen is recomended unlss you can live with the 'bubbles"
Posted on Apr 27, 2008
  • Scott Hill
    Scott Hill Apr 27, 2008
    yes it can get worse the air will come in from the side that the cf light tube is closest too. like I said unless you want to live with it replacement is indicated.
    Scholar:
  • 99 Answers
Your Licquid Crystal Display appears to have gone bad... much like a dead pixel in a TV, you get a dead spot on the display of your lcd that looks like a bubbe.
You need to have the screen replaced or you will have to live with the bubbles. If the PC is still under warranty I'd send it in for repair. You may be able to pick up an inexpensive replacement on eBay, but make sure you are careful if you replace the screen yourself.
I have colored spots appearing on my screen when the TV is on. The spots are 2 to 6 inches in diameter and always appear in the same locations at various places on the screen. The first spots I noticed...
the light engine (optical block) is failing. there are lcd panels and light filters in the light engine. the problem your having is that they over heated and the image is burnt into the lcd or light filter. my be caused by a failing fan or just it's life span. the lcd panel or light filter are done for. you can keep calling panasonic and bug them over and over and they may send you a new tv. sony sent me one after 5 phone calls. i had the same problem. hope this helps.
Jan 14, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Hi this is prince here from Bangladesh. i have a laptop that is acer travel mate 420. a few days ago its display is not working properly. some times it turn into various color. so what can i do?
Hi Prince, has your laptop experienced a squeeze or fall recently? I have a few suggestions. Plug another monitor into the VGA or DVI connection on your laptop. See if you are getting the same problem. If everything is working fine on the external monitor you would have eliminated the drivers being the problem. I suggest getting the LCD display changed. If your laptop is under warranty, you can get this done for free. However, if it is not under warranty you may have to replace it either yourself or take it to a local Acer specialist. If you chose to install the new display yourself, there are handy tutorials on removing and installing the screen on the Acer website. I have noticed that many times the Acer TravelMate Notebooks have experienced display issues. I hope you get your problem resolved soon.
Thanks for using FixYa.com!!
Apr 18, 2010 | Acer TravelMate 4200 Notebook
Spot like watermark on screen
When you see this starting to develope it is usually indicative of the screen delaminating. The different layers of the lcd may be failing and the picture will start to get more and more destorted. There is no fix except screen replacement.
Dec 26, 2009 | Acer TravelMate 6291-6753 Notebook
My rear projection TV has color spots in the picture, most noticeable on light color picture
What is the make and model of TV. If it is a Panasonic that has different colored spots such as pink, blue etc. Then you need t6o contact Panasonic as this is a memory reset that they have to perform on the LCD driver board. Other brands of LCD projection sets that have spots that appear all over the screen mostly on white back rounds are almost always dust that has settled on the LCD panels. This requires a technician to clean the LCD panels if possible.
Dec 17, 2009 | Hitachi Televison & Video
We have an acer travelmate 2410 and recently we noticed the keyboard would not work on some of the search boxes, we hope maybe you can help
Hello. Uninstall the reinstall the keyboard from the device manager.
That should solve the problem if this is related to drivers.
thanks
Oct 24, 2009 | Acer TravelMate 2300 Notebook
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Spots on my display
There's nothing wrong with your camcorder. Cystal-shaped spots, black spots, and bright spots of light (red, green, or blue) can appear on the LCD monitor for a variety of reasons. These spots are not being recorded on your tape. But if these are distracting your videotaping, consider taking a slightly different shooting angle and the spots should go away.
Sep 06, 2005 | RCA CC-432 Camcorder
Acer TravelMate 4150LCi Notebook Logo
1,236 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
